my new beta GIS Software ElshayalSmart for map and data base
editing and drawing
Mr. Mohamed Elshayal
elshayal at SMARTWEBONLINE.COM
Mon Apr 17 21:36:31 EDT 2006
Dear Andrew
Thank you for your reply
When I start building this software, I was drawing the map directly from
files without loading it into memory
It was not very slow, but it was very complicated , so I ignored this
solution.
I believe I will reconsider this solution again
I used Loading into memory to get the advantage of discarding all changes
without saving them to disk
but, I have solved this problem in table files, by using tmp files for
saving or discarding changes
Table data changes by editing or by VB script code will be saved into tmp
files until you save it
I am still working in "Undo function" and viewing raster images
Thank you and best personal regards
Mohamed Elshayal
----- Original Message -----
From: "Andrew Williams" <awilliams at RAPIDMAP.COM.AU>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, April 18, 2006 1:37 AM
Subject: Re: [UMN_MAPSERVER-USERS] my new beta GIS Software ElshayalSmart
for map and data base editing and drawing
> Mohamed,
> It has most of what an entry level GIS would need. The one thing that I
> look for in new GIS tools is the speed with which they open a file. Your
> system is quite slow. The reason is due to your application opening the
> entire file into memory. For small files this is OK, for large files this
> is a problem. The applications that open files quickly use spatial
> indexing to optimise the amount of information loaded into memory at any
> one time. Make better use of spatial indexing (it's hard I know) and you
> will have a good tool.
> You should be proud of your achievement.
> regards
> Andrew
> -----Original Message-----
> From: Mr. Mohamed Elshayal [mailto:elshayal at SMARTWEBONLINE.COM]
> Sent: Tue 4/18/2006 2:15 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Cc:
> Subject: [UMN_MAPSERVER-USERS] my new beta GIS Software ElshayalSmart for
> Dear Sirs,
> I have published my new beta GIS Software ElshayalSmart for map and data
> Kindly, please download it at http://www.smartwebonline.com/
> or at
> http://www.gismagazine.com/downloads/download.php?id=143
> and test it and inform me by your ideas and points of view
> Mohamed Elshayal
