Postgis Gist Index
Mark Cave-Ayland
m.cave-ayland at WEBBASED.CO.UK
Wed Apr 19 03:25:19 EDT 2006
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Paul Ramsey
> Sent: 19 April 2006 01:19
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Postgis Gist Index
> This is just tickling the end of my cerebral cortex -- I am sure I
> have seen something like this before. If you make your box smaller
> and smaller, does the index kick in eventually in mapserver?
> P
Hi Paul,
Would this be the incident you are thinking of here?
http://archives.postgresql.org/pgsql-hackers/2003-10/msg00059.php
I imagine that this could be solved by manually tweaking some of the cost
settings in postgresql.conf.
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
