Parsing GetCapabilities in MapServer?
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Apr 19 08:42:18 EDT 2006
Chameleon has functionality for this called wmsparse.
It is available as a CGI or as a PHP module, and stores the parsed info in
dbf files.
See:
For the CGI:
chameleon/htdocs/common/wmsparse
For the PHP code around it:
chameleon/htdocs/common/phpwms
and for the PHP module:
chameleon/ext
Chameleon is available here:
http://www.maptools.org/chameleon <http://www.maptools.org/chameleon>
For more questions, use the chameleon e-mail list.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
Michael S. Birkmose
Verzonden: woensdag 19 april 2006 14:06
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Parsing GetCapabilities in MapServer?
I'm currently building a WMS client using mapserver.
The WMS client will be part of an application where the user can add his own
WMS layers by inputting the XML document received when calling the
GetCapabilities method in a WMS service.
Does anyone know of a tool that can parse this XML document or is it
possible to do using php mapscript?
Best regards,
Michael
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060419/871ea4b3/attachment.html
