MapScript Save to GeoTiff or Tiff/worldfile
Simpson
asimpson at I-55.COM
Wed Apr 19 08:59:16 EDT 2006
In MapScript 4.8.1 with GDAL 1.3.1.0, is there anything special one has to
do to save image to GeoTiff or to a Tiff with worldfile?
In the GeoTiff case, the tiff is created but no CRS info when I run a
gdalinfo against it.
In the Tiff with worldfile, no worldfile is created.
Thanks for any help,
Drew.
============= mapfile clip =====================
MAP
EXTENT 764355.44479 3337347.51664 834777.592259 3402902.747157
FONTSET "xxx"
IMAGECOLOR 156 188 217
IMAGETYPE GTIFWLD
SYMBOLSET "xxx"
SIZE 2347 2185
STATUS ON
UNITS METERS
NAME "DIPEX3"
OUTPUTFORMAT
NAME "GTIFWLD"
MIMETYPE "image/tiff"
DRIVER "GDAL/GTiff"
EXTENSION "tif"
IMAGEMODE "PC256"
TRANSPARENT FALSE
FORMATOPTION "WORLDFILE=YES"
END
PROJECTION
"init=epsg:32615"
END
END
============= gdalinfo clip =======================
Driver: GTiff/GeoTIFF
Size is 2347, 2185
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 2185.0)
Upper Right ( 2347.0, 0.0)
Lower Right ( 2347.0, 2185.0)
Center ( 1173.5, 1092.5)
Band 1 Block=2347x3 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 156,188,217,255
1: 0,0,0,255
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060419/245566da/attachment.html
