MapScript Save to GeoTiff or Tiff/worldfile
Shoaib Burq
hydromap at GMAIL.COM
Fri Apr 21 23:09:13 EDT 2006
you might want to look at the WCS for this purposes. i don't think
world files are supported but certainly the internally georeferenced
geotiffs work.
On 4/19/06, Simpson <asimpson at i-55.com> wrote:
> In MapScript 4.8.1 with GDAL 1.3.1.0, is there anything special one has to
> do to save image to GeoTiff or to a Tiff with worldfile?
> In the GeoTiff case, the tiff is created but no CRS info when I run a
> gdalinfo against it.
> In the Tiff with worldfile, no worldfile is created.
> Thanks for any help,
> Drew.
> ============= mapfile clip =====================
> MAP
> EXTENT 764355.44479 3337347.51664 834777.592259 3402902.747157
> FONTSET "xxx"
> IMAGECOLOR 156 188 217
> IMAGETYPE GTIFWLD
> SYMBOLSET "xxx"
> SIZE 2347 2185
> STATUS ON
> UNITS METERS
> NAME "DIPEX3"
> OUTPUTFORMAT
> NAME "GTIFWLD"
> MIMETYPE "image/tiff"
> DRIVER "GDAL/GTiff"
> EXTENSION "tif"
> IMAGEMODE "PC256"
> TRANSPARENT FALSE
> FORMATOPTION "WORLDFILE=YES"
> END
> PROJECTION
> "init=epsg:32615"
> END
> END
> ============= gdalinfo clip =======================
> Driver: GTiff/GeoTIFF
> Size is 2347, 2185
> Coordinate System is `'
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 2185.0)
> Upper Right ( 2347.0, 0.0)
> Lower Right ( 2347.0, 2185.0)
> Center ( 1173.5, 1092.5)
> Band 1 Block=2347x3 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 156,188,217,255
> 1: 0,0,0,255
