Problem using index files on Unix
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 19 09:59:47 EDT 2006
Olivier LAFIT wrote:
> Hello,
> I still have the problem with index files on Unix TRU64.
> I have try all options of the ShpTree utility to generate my index files,
> but no one works.
> I get sometimes a core file created by program "shp2img" :
> signal Floating point exception at >*[msRectOverlap, 0x1200357a4]
> fbne $f12, 0x1200357b0
> (dbx) where
>> 0 msRectOverlap(0x3ff800e3634, 0x11fffbb50, 0x4, 0x4, 0x3ffc00801a0)
> [0x1200357a4]
> 1 (unknown)() [0x120061fb0]
> 2 (unknown)() [0x120062188]
> 3 (unknown)() [0x120062188]
> 4 (unknown)() [0x120062188]
> 5 msSearchDiskTree(0xc04e99999999999b, 0x405cedb6ed677709,
> 0x40501249129888f8, 0x14007a6c0, 0x4050124900000000) [0x1200622c8]
> 6 msSHPWhichShapes(0xc060e83a7daa4fca, 0xc04e99999999999b,
> 0x405cedb6ed677709, 0x40501249129888f8, 0x3ff0000000000000) [0x12005a160]
> 7 msLayerWhichShapes(0x14001b4c0, 0x1, 0xc060e83a7daa4fca,
> 0xc04e99999999999b, 0x405cedb6ed677709) [0x120049ad0]
> 8 msDrawVectorLayer(0x0, 0x11fffc038, 0x12002426c, 0x14001f000,
> 0x14001f000) [0x1200247a4]
> 9 msDrawLayer(0x14001b4c0, 0x0, 0x140003828, 0x0, 0x100000000)
> [0x120024420]
> 10 msDrawMap(0x3ff0000000000000, 0x4000000000000000, 0x12000e478,
> 0x11fffc018, 0x38) [0x120023594]
> 11 main(0x14001b480, 0x3ffc00800c0, 0x140048700, 0x0, 0x12000e260)
> [0x12000e9e0]
Olivier,
I would suspect a problem with Alpha support. Are you generating the
index files on another system and transporting them to the TRU64 system
for use? I think that would be the preferred approach.
If you can provide details in a bug report *and* an ssh account on your
system, then I would be willing to try and debug this problem, at least
briefly. I am pretty confident that index files work properly on some
64 bit systems so problems should not be insurmountable.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
