help w/ WFS request
John Cartwright
John.C.Cartwright at NOAA.GOV
Wed Apr 19 19:17:12 EDT 2006
Thanks for the suggestion, Bart.
It didn't seem to make any difference though. The request now reads as
listed below. I'm assuming that the
<gml:coordinates>-95,26.5 -94.75,26.75</gml:coordinates>
is referring to "minx,miny maxx,maxy". Also "DUMP TRUE" is set inside the LAYER section.
-- john
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="soundings">
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>msGeometry</ogc:PropertyName>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4269">
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Eijnden, B. van den (Bart) wrote:
>Some more thoughts:
>1. you need to use msGeometry instead of the_geom in your GetFeature request
>2. just checking, but have you set DUMP TRUE on your LAYER?
>Best regards,
>Bart
>-----Oorspronkelijk bericht-----
>Van: UMN MapServer Users List
>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens John Cartwright
>Verzonden: dinsdag 18 april 2006 22:19
>Aan: MAPSERVER-USERS at LISTS.UMN.EDU
>Onderwerp: Re: [UMN_MAPSERVER-USERS] help w/ WFS request
>Thanks for the prompt replies Perry and Bart!
>I found part of my problem was that the TNS_ADMIN variable was not being
>recognized so mapserver was not finding my tnsnames.ora. Having
>corrected that, I now get the correct coordinates in the response, but
>it 's not finding any features. This is mapserver 4.8.3 (on RHEL WS4)
>running against an Oracle (10.1.0.4) spatial data source.
>Here's my current request and response. I expect to find 67 point
>features w/in this particular geographic extent, but the
>featureCollection is coming back empty. The complete
>DescribeFeatureType response is listed at the bottom of the message.
>Thanks again for your help!
>-- john
>Request:
> outputFormat="GML2"
> <ogc:PropertyName>OBJECT_ID</ogc:PropertyName>
> <ogc:Filter>
> <ogc:BBOX>
> <ogc:PropertyName>the_geom</ogc:PropertyName>
> </gml:Box>
> </ogc:BBOX>
> </ogc:Filter>
> </wfs:Query>
></wfs:GetFeature>
>Response (note the empty featureCollection where there should be 67 points):
><?xml version='1.0' encoding="ISO-8859-1" ?>
><wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
>http://lynx.ngdc.noaa.gov:8000/cgi-bin?map=bathydb&SERVICE=WFS&VERSI
>ON=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=soundings&OUTPUTFO
>RMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:Box srsName="EPSG:4269">
> <gml:coordinates>-94.999165,26.504089
>-94.757270,26.742092</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
></wfs:FeatureCollection>
>DescribeFeatureType Response:
><schema
> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns="http://www.w3.org/2001/XMLSchema"
> elementFormDefault="qualified" version="0.1" >
> <import namespace="http://www.opengis.net/gml"
>schemaLocation="http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd" />
> <element name="soundings"
> type="ms:soundingsType"
> substitutionGroup="gml:_Feature" />
> <complexType name="soundingsType">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element name="msGeometry" type="gml:GeometryPropertyType"
>minOccurs="0" maxOccurs="1"/>
> <element name="OBJECT_ID" type="string"/>
> <element name="SURVEY_ID" type="string"/>
> <element name="ORIGINAL_LAT" type="string"/>
> <element name="ORIGINAL_LONG" type="string"/>
> <element name="CALCULATED_LAT" type="string"/>
> <element name="CALCULATED_LONG" type="string"/>
> <element name="ORIGINAL_DEPTH" type="string"/>
> <element name="CURRENT_DEPTH" type="string"/>
> <element name="CARTOCODE" type="string"/>
> <element name="OBJECT_CODE" type="string"/>
> <element name="QUALITY_CODE" type="string"/>
> <element name="ACTIVE" type="string"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
></schema>
>Pericles S. Nacionales wrote:
>>John,
>>On Tuesday 18 April 2006 13:28, John Cartwright wrote:
>>>Hello All,
>>>I'm trying to get mapserver setup as a simple WFS server. It responds to
>>>a GetCapabilities request OK:
>>>but when I send the following GetFeatures request:
>>> outputFormat="GML2"
>>> <ogc:Filter>
>>> <ogc:BBOX>
>>Shouldn't this be "<gml:Box srsName="EPSG:4269">" (or is it EPSG:4326)?
>Looks
>>like the srsName in your mapfile maybe incorrect.
>>-Perry
>>> </gml:Box>
>>> </ogc:BBOX>
>>> </ogc:Filter>
>>> </wfs:Query>
>>></wfs:GetFeature>
>>>I get this response, and don't know what's wrong:
>S
>>>ION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=soundings&OUTPU
>TF
>>>ORMAT=XMLSCHEMA"> <gml:boundedBy>
>>> <gml:null>missing</gml:null>
>>> </gml:boundedBy>
>>>It suggests to me that the bounding box coordinates are not being
>>>properly read. I would have expected something like in the response:
>>><gml:boundedBy>
>>><gml:Box srsName="EPSG:4326">
>>><gml:coordinates> -95, 26.5 -94.75, 26.75</gml:coordinates>
>>></gml:Box>
>>></gml:boundedBy>
>>>followed by a series of featureMember elements.
>>>Can someone tell what I'm doing wrong?
>>>Thanks!
>>>-- john
>Disclaimer
>Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>informeren. Wij adviseren u om bij twijfel over de juistheid of de
>volledigheid van de mail contact met afzender op te nemen.
>This message shall not constitute any rights or obligations.
>This message is intended solely for the addressee.
>If you have received this message in error, please delete it and
>notify the sender immediately. When in doubt whether this message
>is correct or complete, please contact the sender.
