help w/ WFS request
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Thu Apr 20 01:44:06 EDT 2006
Have you tried Perry's suggestion to use:
<gml:Box srsName="EPSG:4269">
<gml:coordinates>-95,26.5 -94.75,26.75</gml:coordinates>
</gml:Box>
What's does your LAYER's PROJECTION block look like?
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens John Cartwright
Verzonden: donderdag 20 april 2006 1:17
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] help w/ WFS request
Thanks for the suggestion, Bart.
It didn't seem to make any difference though. The request now reads as
listed below. I'm assuming that the
is referring to "minx,miny maxx,maxy". Also "DUMP TRUE" is set inside the
LAYER section.
-- john
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="soundings">
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>msGeometry</ogc:PropertyName>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4269">
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Eijnden, B. van den (Bart) wrote:
>Some more thoughts:
>1. you need to use msGeometry instead of the_geom in your GetFeature
request
>2. just checking, but have you set DUMP TRUE on your LAYER?
>Best regards,
>Bart
>Verzonden: dinsdag 18 april 2006 22:19
>Thanks for the prompt replies Perry and Bart!
>I found part of my problem was that the TNS_ADMIN variable was not being
>recognized so mapserver was not finding my tnsnames.ora. Having
>corrected that, I now get the correct coordinates in the response, but
>it 's not finding any features. This is mapserver 4.8.3 (on RHEL WS4)
>running against an Oracle (10.1.0.4) spatial data source.
>Here's my current request and response. I expect to find 67 point
>features w/in this particular geographic extent, but the
>featureCollection is coming back empty. The complete
>DescribeFeatureType response is listed at the bottom of the message.
>Thanks again for your help!
>-- john
>Request:
> outputFormat="GML2"
> <ogc:PropertyName>OBJECT_ID</ogc:PropertyName>
> <ogc:Filter>
> <ogc:BBOX>
> <ogc:PropertyName>the_geom</ogc:PropertyName>
> </gml:Box>
> </ogc:BBOX>
> </ogc:Filter>
> </wfs:Query>
></wfs:GetFeature>
>Response (note the empty featureCollection where there should be 67
points):
><?xml version='1.0' encoding="ISO-8859-1" ?>
><wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd
>http://lynx.ngdc.noaa.gov:8000/cgi-bin?map=bathydb&SERVICE=WFS&VERS
I
>ON=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=soundings&OUTPUTF
O
>RMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:coordinates>-94.999165,26.504089
>-94.757270,26.742092</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
></wfs:FeatureCollection>
>DescribeFeatureType Response:
><schema
> targetNamespace="http://mapserver.gis.umn.edu/mapserver"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xmlns="http://www.w3.org/2001/XMLSchema"
> elementFormDefault="qualified" version="0.1" >
> <import namespace="http://www.opengis.net/gml"
>schemaLocation="http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd" />
> <element name="soundings"
> type="ms:soundingsType"
> substitutionGroup="gml:_Feature" />
> <complexType name="soundingsType">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element name="msGeometry" type="gml:GeometryPropertyType"
>minOccurs="0" maxOccurs="1"/>
> <element name="OBJECT_ID" type="string"/>
> <element name="SURVEY_ID" type="string"/>
> <element name="ORIGINAL_LAT" type="string"/>
> <element name="ORIGINAL_LONG" type="string"/>
> <element name="CALCULATED_LAT" type="string"/>
> <element name="CALCULATED_LONG" type="string"/>
> <element name="ORIGINAL_DEPTH" type="string"/>
> <element name="CURRENT_DEPTH" type="string"/>
> <element name="CARTOCODE" type="string"/>
> <element name="OBJECT_CODE" type="string"/>
> <element name="QUALITY_CODE" type="string"/>
> <element name="ACTIVE" type="string"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
></schema>
>Pericles S. Nacionales wrote:
>>John,
>>On Tuesday 18 April 2006 13:28, John Cartwright wrote:
>>>Hello All,
>>>I'm trying to get mapserver setup as a simple WFS server. It responds to
>>>a GetCapabilities request OK:
>>>but when I send the following GetFeatures request:
>>> outputFormat="GML2"
>>> <ogc:Filter>
>>> <ogc:BBOX>
>>Shouldn't this be "<gml:Box srsName="EPSG:4269">" (or is it EPSG:4326)?
>Looks
>>like the srsName in your mapfile maybe incorrect.
>>-Perry
>>> </gml:Box>
>>> </ogc:BBOX>
>>> </ogc:Filter>
>>> </wfs:Query>
>>></wfs:GetFeature>
>>>I get this response, and don't know what's wrong:
R
>S
>>>ION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=soundings&OUTP
U
>TF
>>>ORMAT=XMLSCHEMA"> <gml:boundedBy>
>>> <gml:null>missing</gml:null>
>>> </gml:boundedBy>
>>>It suggests to me that the bounding box coordinates are not being
>>>properly read. I would have expected something like in the response:
>>><gml:boundedBy>
>>><gml:Box srsName="EPSG:4326">
>>><gml:coordinates> -95, 26.5 -94.75, 26.75</gml:coordinates>
>>></gml:Box>
>>></gml:boundedBy>
>>>followed by a series of featureMember elements.
>>>Can someone tell what I'm doing wrong?
>>>Thanks!
>>>-- john
>Disclaimer
>Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>informeren. Wij adviseren u om bij twijfel over de juistheid of de
>volledigheid van de mail contact met afzender op te nemen.
>This message shall not constitute any rights or obligations.
>This message is intended solely for the addressee.
>If you have received this message in error, please delete it and
>notify the sender immediately. When in doubt whether this message
>is correct or complete, please contact the sender.
Disclaimer
