Mapserver as a WMS client behind a proxy (MS4W)
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu Apr 20 08:54:39 EDT 2006
Yes, use the no_proxy environment variable.
Best regards,
Bart
> Hi again,
> Now I would like to use external WMS service, but also my own WFS server
> (not Mapserver) at the same time. And that server in _inside_ the proxy
> and should be connected without http_proxy. Might it be possible to give
> proxy exceptions to curl in some way?
> Regards,
> -Jukka-
>>Mapserver WMS client uses curl, and curl listens to the http_proxy
>>You need to set your http_proxy variable using SetEnv in the httpd.conf
>> and
>>restart Apache.
>>SetEnv "http_proxy" "http://myproxy.com"
>>Best regards,
>>Bart
