commas in CONNECTION string cause MapServer to fail
Szekeres Tamás
szekeres.tamas at FREEMAIL.HU
Thu Apr 20 11:06:14 EDT 2006
There is a bug in connection with this problem
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1549
However it has not been fixed yet as far as I know.
Best Regards
Tamas Szekeres
On Thu, 20 Apr 2006 09:37:44 -0500, Mark Adams
<Mark.Adams at DPRA.COM> wrote:
>Hi all,
>We're working on an application that uses a virtual spatial
layer coming
>from an Oracle database using WKT geometry. For performance and
>presentation reasons, we are setting the CONNECTION string
dynamically
>based on the user's selected parameters on a query form.
The CONNECTION
>is being set by including the OGR virtual layer definition
in-line, such
>as:
>CONNECTION "<OGRVRTDataSource>
> <OGRVRTLayer name='Reference_Query'>
<SrcDataSource>ODBC:system/normin at normin_dev</SrcDataSource>
> <SrcSQL>SELECT * FROM
MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE
>WHERE
MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR
IS NOT
>NULL</SrcSQL>
> <GeometryType>wkbPolygon</GeometryType>
> <GeometryField encoding='WKT' field='GEOMETRY'/>
> </OGRVRTLayer>
></OGRVRTDataSource>"
>The above example works fine. However, when we include
commas in the
>SrcSQL element, such as "SELECT FIELD1,FIELD2 FROM
TABLE1,TABLE2",
>mapserver crashes with:
>[MapServer Error]: msOGRFileOpen(): Open failed for OGR
connection
>`<OGRVRTDataSource>
> <SrcSQL>SELECT
>MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR'.
>Parse error at EOF, not all elements have been closed,
>starting with SrcSQL
>Is this behaviour expected, i.e. are commas disallowed in
the MAP file,
>and if so is there a way to escape them? I can put the
exact same string
>in an OVF file and set the CONNECTION to that file, and
then it works,
>so I know there is nothing wrong with the string itself.
>Thanks.
>Mark Adams
>Senior Analyst & Project Manager
>Cuesta Systems (DPRA Canada)
>5230 South Service Road
>Burlington, ON L7L 5K2
>Phone: 905-333-4544 x14
>Fax: 905-333-0455
>Email: mark.adams at dpra.com
_______________________________________________________________________________
Hogyan szerezz új állást? Regisztrálj, állítsd be a feltételeket, és naponta új, neked megfelelő ajánlatok
érkeznek emailcímedre. Jobline Állásposta: http://ad.adverticum.net/b/cl,1,6022,98196,159883/click.prm
