commas in CONNECTION string cause MapServer to fail
Mark Adams
Mark.Adams at DPRA.COM
Thu Apr 20 10:37:44 EDT 2006
Hi all,
We're working on an application that uses a virtual spatial layer coming
from an Oracle database using WKT geometry. For performance and
presentation reasons, we are setting the CONNECTION string dynamically
based on the user's selected parameters on a query form. The CONNECTION
is being set by including the OGR virtual layer definition in-line, such
as:
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='Reference_Query'>
<SrcDataSource>ODBC:system/normin at normin_dev</SrcDataSource>
<SrcSQL>SELECT * FROM MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE
WHERE MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR IS NOT
NULL</SrcSQL>
<GeometryType>wkbPolygon</GeometryType>
<GeometryField encoding='WKT' field='GEOMETRY'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
The above example works fine. However, when we include commas in the
SrcSQL element, such as "SELECT FIELD1,FIELD2 FROM TABLE1,TABLE2",
mapserver crashes with:
[MapServer Error]: msOGRFileOpen(): Open failed for OGR connection
`<OGRVRTDataSource>
<SrcSQL>SELECT
MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR'.
Parse error at EOF, not all elements have been closed,
starting with SrcSQL
Is this behaviour expected, i.e. are commas disallowed in the MAP file,
and if so is there a way to escape them? I can put the exact same string
in an OVF file and set the CONNECTION to that file, and then it works,
so I know there is nothing wrong with the string itself.
Thanks.
Mark Adams
Senior Analyst & Project Manager
Cuesta Systems (DPRA Canada)
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: mark.adams at dpra.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060420/6684423d/attachment.html
