help w/ WFS request
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Thu Apr 20 12:37:21 EDT 2006
Hi John,
it's becoming a strange problem ... you could try Mapserver "debugging",
see:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?DebuggingMapserver
Can you first make sure your WFS is working by just trying a HTTP GET
request to your WFS, so try:
?map=.....&service=WFS&request=GetFeature&version=1.0.0&typename=soundings&maxfeatures=10
Best regards,
Bart
John Cartwright wrote:
> Hi Bart,
> yes, I did - same results:
> <gml:Box srsName="epsg:4269">
> <gml:coordinates>-95,26.5 -94.75,26.75</gml:coordinates>
> </gml:Box>
> "EPSG:4269" and "epsg:4269" produce the same results in the request,
> but the mapfile seems to only recognize the lowercase representation.
> from the mapfile:
> DATA "SHAPE FROM BATHYUSER.SOUNDING USING SRID 8265"
> PROJECTION
> "init=epsg:4269"
> END
> Is there a way that I can see any more detail on how mapserver "sees"
> the request?
> Thanks!
> -- john
> Eijnden, B. van den (Bart) wrote:
>> Have you tried Perry's suggestion to use:
>> <gml:Box srsName="EPSG:4269">
>> </gml:Box>
>> What's does your LAYER's PROJECTION block look like?
>> Best regards,
>> Bart
OSGIS, Open Source GIS
http://www.osgis.nl
