help w/ WFS request
Pericles S. Nacionales
naci0002 at UMN.EDU
Thu Apr 20 12:55:37 EDT 2006
John,
Can you confirm that the SQL query works outside of MapServer? This could
well be a MapServer bug (and I suspect is related to PostGIS query problems
thaat some users are experiencing). You might have to enable the debugging
mode to get more info.
-Perry
On Thursday 20 April 2006 11:23, John Cartwright wrote:
> Hi Bart,
> yes, I did - same results:
> <gml:Box srsName="epsg:4269">
> <gml:coordinates>-95,26.5 -94.75,26.75</gml:coordinates>
> </gml:Box>
> "EPSG:4269" and "epsg:4269" produce the same results in the request, but
> the mapfile seems to only recognize the lowercase representation.
> from the mapfile:
> DATA "SHAPE FROM BATHYUSER.SOUNDING USING SRID 8265"
> PROJECTION
> "init=epsg:4269"
> END
> Is there a way that I can see any more detail on how mapserver "sees"
> the request?
> Thanks!
> -- john
> Eijnden, B. van den (Bart) wrote:
> > Have you tried Perry's suggestion to use:
> > <gml:Box srsName="EPSG:4269">
> > </gml:Box>
> > What's does your LAYER's PROJECTION block look like?
> > Best regards,
> > Bart
Conservation Biology Program
University of Minnesota
e-mail: naci0002 at umn.edu
