commas in CONNECTION string cause MapSe rver to fail
Stephane Lessard
LESSARDST at DFO-MPO.GC.CA
Thu Apr 20 14:01:58 EDT 2006
Hi Mark,
It has to be a syntax error. I use commas all the time. Could you provide
the whole virtual layer definition?
Stephane
_____
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de Mark Adams
Envoyé : 20 avril 2006 10:38
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] commas in CONNECTION string cause MapServer to
fail
Hi all,
We're working on an application that uses a virtual spatial layer coming
from an Oracle database using WKT geometry. For performance and presentation
reasons, we are setting the CONNECTION string dynamically based on the
user's selected parameters on a query form. The CONNECTION is being set by
including the OGR virtual layer definition in-line, such as:
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='Reference_Query'>
<SrcDataSource>ODBC:system/normin at normin_dev</SrcDataSource>
<SrcSQL>SELECT * FROM MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE
WHERE MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR IS NOT
NULL</SrcSQL>
<GeometryType>wkbPolygon</GeometryType>
<GeometryField encoding='WKT' field='GEOMETRY'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
The above example works fine. However, when we include commas in the SrcSQL
element, such as "SELECT FIELD1,FIELD2 FROM TABLE1,TABLE2", mapserver
crashes with:
[MapServer Error]: msOGRFileOpen(): Open failed for OGR connection
`<OGRVRTDataSource>
<SrcSQL>SELECT
MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR'.
Parse error at EOF, not all elements have been closed,
starting with SrcSQL
Is this behaviour expected, i.e. are commas disallowed in the MAP file, and
if so is there a way to escape them? I can put the exact same string in an
OVF file and set the CONNECTION to that file, and then it works, so I know
there is nothing wrong with the string itself.
Thanks.
Mark Adams
Senior Analyst & Project Manager
Cuesta Systems (DPRA Canada)
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: mark.adams at dpra.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060420/82311d84/attachment.html
