commas in CONNECTION string cause MapServer to fail
Mark Adams
Mark.Adams at DPRA.COM
Thu Apr 20 14:50:25 EDT 2006
Like I said, if I put this in the OVF file instead of including it inline, it works. Inline, it craps out at the first comma. I can test this by removing the tablename from the SrcDataSource element for example, and then it craps out at SrcSQL instead - first comma it finds. Here is the LAYER definition:
LAYER
NAME 'References'
CONNECTIONTYPE OGR
#CONNECTION "ODBC:MINFWHSE_P1/MINFWHSE_P1 at MINFWHSE_P1,MINFT_WH2_REFER_REFERENCE"
#CONNECTION "REFERENCES_minf_read.ovf"
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='Reference_Query'>
<SrcDataSource>ODBC:system/normin at normin_dev,MINFT_WH2_REFER_REFERENCE</SrcDataSource>
<SrcSQL>SELECT MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.GEOMETRY,MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR FROM MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE WHERE MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.GEOMETRY IS NOT NULL</SrcSQL>
<GeometryType>wkbPolygon</GeometryType>
<GeometryField encoding='WKT' field='GEOMETRY'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
STATUS off
TYPE Polygon
TRANSPARENCY 100
TOLERANCE 7
TOLERANCEUNITS pixels
TEMPLATE "null"
METADATA
WMS_SRS 'epsg:4326'
WMS_TITLE 'WMSTitel'
WMS_FEATURE_INFO_MIME_TYPE 'text/html'
END #METADATA
PROJECTION
'init=epsg:99999'
END
CLASS
NAME 'References'
STYLE
#COLOR 150 180 250
OUTLINECOLOR 0 0 0
WIDTH 1.5
END #STYLE
END #CLASS
END #LAYER
Mark Adams
Senior Analyst & Project Manager
Cuesta Systems (DPRA Canada)
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: mark.adams at dpra.com
From: LESSARDST at dfo-mpo.gc.ca [mailto:LESSARDST at dfo-mpo.gc.ca]
Sent: April 20, 2006 2:02 PM
To: Mark Adams; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] commas in CONNECTION string cause MapServer to fail
Hi Mark,
It has to be a syntax error. I use commas all the time. Could you provide the whole virtual layer definition?
Stephane
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de Mark Adams
Envoyé : 20 avril 2006 10:38
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] commas in CONNECTION string cause MapServer to fail
Hi all,
We're working on an application that uses a virtual spatial layer coming from an Oracle database using WKT geometry. For performance and presentation reasons, we are setting the CONNECTION string dynamically based on the user's selected parameters on a query form. The CONNECTION is being set by including the OGR virtual layer definition in-line, such as:
<SrcDataSource>ODBC:system/normin at normin_dev</SrcDataSource>
<SrcSQL>SELECT * FROM MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE WHERE MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR IS NOT NULL</SrcSQL>
</OGRVRTLayer>
The above example works fine. However, when we include commas in the SrcSQL element, such as "SELECT FIELD1,FIELD2 FROM TABLE1,TABLE2", mapserver crashes with:
[MapServer Error]: msOGRFileOpen(): Open failed for OGR connection `<OGRVRTDataSource>
<SrcSQL>SELECT MINFWHSE_P1.MINFT_WH2_REFER_REFERENCE.C_REFER_REFERENCE_NBR'.
Parse error at EOF, not all elements have been closed,
starting with SrcSQL
Is this behaviour expected, i.e. are commas disallowed in the MAP file, and if so is there a way to escape them? I can put the exact same string in an OVF file and set the CONNECTION to that file, and then it works, so I know there is nothing wrong with the string itself.
Thanks.
Mark Adams
Fax: 905-333-0455
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060420/fe6a403c/attachment.html
