randomly assigned COLOR 's?
Abe Gillespie
abe.gillespie at GMAIL.COM
Fri Apr 21 13:22:15 EDT 2006
Using the EXPRESSION option sounds like a good idea to me. You can
take it a step further to have dynamic random colors instead of the
static scheme you speak of. You could import the data into PostGIS.
Then, you can probably construct a clever SELECT statement that uses
PostgreSQL / PostGIS functions to generate a column containing random
numbers. Of course it might be tricky to have the random numbers
dynamic on a per session basis.
Good luck.
-Abe
On 4/21/06, Brent Pedersen <bpederse at nature.berkeley.edu> wrote:
> hi,
> with a map of the world with country boundaries and
> using only the mapserver CGI, is it possible to have the countries
> filled with one of ~5 different colors. either at random or
> uniformly. is there a way to do this in the mapfile without relying
> on attributes in the shapefile?
> my fallback solution will be to add a column in the .shp and assign
> number 1 - 5 to each country and use that in a map file EXPRESSION. i
> thought maybe there was another means i was missing. something like
> an automatic alternating color scheme... to help me do less work.
> thanks,
> -brent
