randomly assigned COLOR 's?
Fawcett, David
David.Fawcett at STATE.MN.US
Fri Apr 21 13:46:48 EDT 2006
Brent,
Since your countries shapefile likely won't change very often, I would
go with your fallback solution.
It is always faster to pre-class your data.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Brent Pedersen
Sent: Friday, April 21, 2006 11:41 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] randomly assigned COLOR 's?
hi,
with a map of the world with country boundaries and
using only the mapserver CGI, is it possible to have the countries
filled with one of ~5 different colors. either at random or
uniformly. is there a way to do this in the mapfile without relying
on attributes in the shapefile?
my fallback solution will be to add a column in the .shp and assign
number 1 - 5 to each country and use that in a map file EXPRESSION. i
thought maybe there was another means i was missing. something like
an automatic alternating color scheme... to help me do less work.
thanks,
-brent
