randomly assigned COLOR 's?
Brent Pedersen
bpederse at NATURE.BERKELEY.EDU
Thu Apr 27 18:07:35 EDT 2006
hi, thanks for the replies, since i wanted to keep as a shapefile, i
just opened it up in open office, added a column, alternated 1..5,
and added the appropriate classes to my .map file. pretty painless.
-brent
On Apr 21, 2006, at 10:46 AM, Fawcett, David wrote:
> Brent,
> Since your countries shapefile likely won't change very often, I would
> go with your fallback solution.
> It is always faster to pre-class your data.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-
> USERS at LISTS.UMN.EDU] On
> Behalf Of Brent Pedersen
> Sent: Friday, April 21, 2006 11:41 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] randomly assigned COLOR 's?
> hi,
> with a map of the world with country boundaries and
> using only the mapserver CGI, is it possible to have the countries
> filled with one of ~5 different colors. either at random or
> uniformly. is there a way to do this in the mapfile without relying
> on attributes in the shapefile?
> my fallback solution will be to add a column in the .shp and assign
> number 1 - 5 to each country and use that in a map file EXPRESSION. i
> thought maybe there was another means i was missing. something like
> an automatic alternating color scheme... to help me do less work.
> thanks,
> -brent
