Error in installation and to mapserver 4.8.3
Tyler Mitchell
tylermitchell at SHAW.CA
Fri Apr 21 13:51:19 EDT 2006
Eduardo,
Have you compiled MapServer once before? How did you install GD - was it using an RPM package or was it already part of your operating system? I suspect that you may have installed it using a gd rpm file, in that case you need to also install the gd-devel rpm. This will provide the necessary files for compiling GD support into MapServer.
Hope that helps!
Tyler
----- Original Message -----
Date: Friday, April 21, 2006 10:04 am
Subject: [UMN_MAPSERVER-USERS] Error in installation and to mapserver 4.8.3
> hello:
> At the moment to execute following
> $. /configure
> $ ./configure --prefix=/usr/local/mapserver
> --with-ogr=/usr/local/gdal/bin/gdal-config
> --with-gdal=/usr/local/gdal/bin/gdal-config --with-
> apache=/usr/local/apache2--with-httpd=/usr/local/apache2/bin --
> with-wfsclient --with-wmsclient
> --enable-debug --with-curl-config=/usr/bin/curl-config
> --with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
> --with-gd=/usr/local/gd/lib --with-jpeg=/usr/lib
> --with-freetype=/usr/local/freetype2/bin/freetype-config
> --with-postgis=/var/lib/pgsql/bin/pg_config
> it finishes executing and it reports the following error ......
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /usr/local/gd/lib.
> Make sure GD 2.0.16 or higher is compiled before calling
> configure. You may
> als
> o get this error if you didn't specify the appropriate location
> for one of
> GD's
> dependencies (freetype, libpng, libjpeg or libiconv).
> reports the same error when executing simple
> $. /configure
> the version of gd installed is gd 2.0.33
> aid please
> excuse the english
