Error in installation and to mapserver 4.8.3
J. Parapar
listario at GMAIL.COM
Fri Apr 21 13:59:18 EDT 2006
Eduardo,
Have you checked that libgd is in /usr/local/gd/lib?
Best regards,
Jorge
2006/4/21, Eduardo Arévalo <earevaloch at gmail.com>:
> hello:
> At the moment to execute following
> $. /configure
> $ ./configure --prefix=/usr/local/mapserver
> --with-ogr=/usr/local/gdal/bin/gdal-config
> --with-gdal=/usr/local/gdal/bin/gdal-config
> --with-apache=/usr/local/apache2
> --with-httpd=/usr/local/apache2/bin --with-wfsclient
> --with-wmsclient --enable-debug
> --with-curl-config=/usr/bin/curl-config
> --with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
> --with-gd=/usr/local/gd/lib --with-jpeg=/usr/lib
> --with-freetype=/usr/local/freetype2/bin/freetype-config
> --with-postgis=/var/lib/pgsql/bin/pg_config
> it finishes executing and it reports the following error ......
> configure: error: Could not find gd.h or libgd.a/libgd.so in
> /usr/local/gd/lib.
> Make sure GD 2.0.16 or higher is compiled before calling configure. You
> may als
> o get this error if you didn't specify the appropriate location for one of
> GD's
> dependencies (freetype, libpng, libjpeg or libiconv).
> reports the same error when executing simple
> $. /configure
> the version of gd installed is gd 2.0.33
> aid please
> excuse the english
