Error in installation and to mapserver 4.8.3
Eduardo Arévalo
earevaloch at GMAIL.COM
Fri Apr 21 15:27:53 EDT 2006
Tyler
if it is first you see.
the these two GD installs of gd-2.0.33.tar.gz
freetype also was freetype-2.1.10.tar.gz
librerias libpng, libjpeg in /usr/lib settle with the system.
The operating system is Centos 4,2
gd.h this in /usr/local/gd/include and this in /usr/local/gd libgd.a/libgd.so
excuse the english
2006/4/21, Tyler Mitchell <tylermitchell at shaw.ca>:
> Eduardo,
> Have you compiled MapServer once before? How did you install GD - was it
> using an RPM package or was it already part of your operating system? I
> suspect that you may have installed it using a gd rpm file, in that case you
> need to also install the gd-devel rpm. This will provide the necessary
> files for compiling GD support into MapServer.
> Hope that helps!
> Tyler
> ----- Original Message -----
> From: Eduardo Arévalo <earevaloch at GMAIL.COM>
> Date: Friday, April 21, 2006 10:04 am
> Subject: [UMN_MAPSERVER-USERS] Error in installation and to mapserver
> 4.8.3
> > hello:
> > At the moment to execute following
> > $. /configure
> > $ ./configure --prefix=/usr/local/mapserver
> > --with-ogr=/usr/local/gdal/bin/gdal-config
> > --with-gdal=/usr/local/gdal/bin/gdal-config --with-
> > apache=/usr/local/apache2--with-httpd=/usr/local/apache2/bin --
> > with-wfsclient --with-wmsclient
> > --enable-debug --with-curl-config=/usr/bin/curl-config
> > --with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
> > --with-gd=/usr/local/gd/lib --with-jpeg=/usr/lib
> > --with-freetype=/usr/local/freetype2/bin/freetype-config
> > --with-postgis=/var/lib/pgsql/bin/pg_config
> > it finishes executing and it reports the following error ......
> > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > /usr/local/gd/lib.
> > Make sure GD 2.0.16 or higher is compiled before calling
> > configure. You may
> > als
> > o get this error if you didn't specify the appropriate location
> > for one of
> > GD's
> > dependencies (freetype, libpng, libjpeg or libiconv).
> > reports the same error when executing simple
> > $. /configure
> > the version of gd installed is gd 2.0.33
> > aid please
> > excuse the english
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060421/37b651fc/attachment.html
