Error in installation and to mapserver 4.8.3
Eduardo Arévalo
earevaloch at GMAIL.COM
Fri Apr 21 16:42:05 EDT 2006
Jorge:
in /usr/local/gd/lib/libgd.a libgd.la libgd.so.2 libgd.so.2.0.0
2006/4/21, J. Parapar <listario at gmail.com>:
> Eduardo,
> Have you checked that libgd is in /usr/local/gd/lib?
> Best regards,
> Jorge
> 2006/4/21, Eduardo Arévalo <earevaloch at gmail.com>:
> > hello:
> > At the moment to execute following
> > $. /configure
> > $ ./configure --prefix=/usr/local/mapserver
> > --with-ogr=/usr/local/gdal/bin/gdal-config
> > --with-gdal=/usr/local/gdal/bin/gdal-config
> > --with-apache=/usr/local/apache2
> > --with-httpd=/usr/local/apache2/bin --with-wfsclient
> > --with-wmsclient --enable-debug
> > --with-curl-config=/usr/bin/curl-config
> > --with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
> > --with-gd=/usr/local/gd/lib --with-jpeg=/usr/lib
> > --with-freetype=/usr/local/freetype2/bin/freetype-config
> > --with-postgis=/var/lib/pgsql/bin/pg_config
> > it finishes executing and it reports the following error ......
> > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > /usr/local/gd/lib.
> > Make sure GD 2.0.16 or higher is compiled before calling configure.
> You
> > may als
> > o get this error if you didn't specify the appropriate location for one
> of
> > GD's
> > dependencies (freetype, libpng, libjpeg or libiconv).
> > reports the same error when executing simple
> > $. /configure
> > the version of gd installed is gd 2.0.33
> > aid please
> > excuse the english
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060421/ba2a4e2e/attachment.html
