Error in installation and to mapserver 4.8.3
Clint Johnson
cjohnson at REFRACTIONS.NET
Fri Apr 21 18:03:06 EDT 2006
I believe you should use:
--with-gd=/usr/local/gd/
Do not add the /lib at the end. Try that.
configure (ie automake and friends) will want to run your
/usr/local/gd/bin/gd-config binary to determine where gd's libraries
are; therefore, when you specify --with-gd=/usr/local/gd/lib, it's not
going to find that binary.
You could also try adding the path of gdlib-config into your path
(in bash)
export PATH=$PATH:/usr/local/gd/bin
./configure <args>
Let me know if that works,
-Clint
Eduardo Arévalo wrote:
> Jorge:
> in /usr/local/gd/lib/libgd.a libgd.la <http://libgd.la> libgd.so.2
> libgd.so.2.0.0
> 2006/4/21, J. Parapar <listario at gmail.com <mailto:listario at gmail.com>>:
> Eduardo,
> Have you checked that libgd is in /usr/local/gd/lib?
> Best regards,
> Jorge
> 2006/4/21, Eduardo Arévalo <earevaloch at gmail.com
> <mailto:earevaloch at gmail.com>>:
> > hello:
> > At the moment to execute following
> > $. /configure
> > $ ./configure --prefix=/usr/local/mapserver
> > --with-ogr=/usr/local/gdal/bin/gdal-config
> > --with-gdal=/usr/local/gdal/bin/gdal-config
> > --with-apache=/usr/local/apache2
> > --with-httpd=/usr/local/apache2/bin --with-wfsclient
> > --with-wmsclient --enable-debug
> > --with-curl-config=/usr/bin/curl-config
> > --with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
> > --with-gd=/usr/local/gd/lib --with-jpeg=/usr/lib
> > --with-freetype=/usr/local/freetype2/bin/freetype-config
> > --with-postgis=/var/lib/pgsql/bin/pg_config
> > it finishes executing and it reports the following error ......
> > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > /usr/local/gd/lib.
> > Make sure GD 2.0.16 or higher is compiled before calling
> configure. You
> > may als
> > o get this error if you didn't specify the appropriate location
> for one of
> > GD's
> > dependencies (freetype, libpng, libjpeg or libiconv).
> > reports the same error when executing simple
> > $. /configure
> > the version of gd installed is gd 2.0.33
> > aid please
> > excuse the english
Clint Johnson
Refractions Research Inc.
Cjohnson at refractions.net
