Error in installation and to mapserver 4.8.3
Eduardo Arévalo
earevaloch at GMAIL.COM
Mon Apr 24 10:33:26 EDT 2006
hello Clint:
prove your sugrerencias
I have used different /configure but with mismi result
e.g --with-gd=/usr/local/gd --with-gd=/usr/local/gd/lib
--with-gd=/usr/local/gd/bin --with-gd.
I complete it was to add:
PATH=$PATH:/usr/local/gd/bin
export PATH
in etc/profile (reboot)
same error
2006/4/21, Clint Johnson <cjohnson at refractions.net>:
> I believe you should use:
> Do not add the /lib at the end. Try that.
> configure (ie automake and friends) will want to run your
> /usr/local/gd/bin/gd-config binary to determine where gd's libraries
> are; therefore, when you specify --with-gd=/usr/local/gd/lib, it's not
> going to find that binary.
> You could also try adding the path of gdlib-config into your path
> (in bash)
> export PATH=$PATH:/usr/local/gd/bin
> ./configure <args>
Let me know if that works,
> -Clint
> Eduardo Arévalo wrote:
> > Jorge:
> > in /usr/local/gd/lib/libgd.a libgd.la <http://libgd.la> libgd.so.2
> > libgd.so.2.0.0
> > 2006/4/21, J. Parapar <listario at gmail.com <mailto:listario at gmail.com>>:
> > Eduardo,
> > Have you checked that libgd is in /usr/local/gd/lib?
> > Best regards,
> > Jorge
> > 2006/4/21, Eduardo Arévalo <earevaloch at gmail.com
> > <mailto:earevaloch at gmail.com>>:
> > > hello:
> > > At the moment to execute following
> > > $. /configure
> > > $ ./configure --prefix=/usr/local/mapserver
> > > --with-ogr=/usr/local/gdal/bin/gdal-config
> > > --with-gdal=/usr/local/gdal/bin/gdal-config
> > > --with-apache=/usr/local/apache2
> > > --with-httpd=/usr/local/apache2/bin --with-wfsclient
> > > --with-wmsclient --enable-debug
> > > --with-curl-config=/usr/bin/curl-config
> > > --with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
> > > --with-gd=/usr/local/gd/lib --with-jpeg=/usr/lib
> > > --with-freetype=/usr/local/freetype2/bin/freetype-config
> > > --with-postgis=/var/lib/pgsql/bin/pg_config
> > > it finishes executing and it reports the following error ......
> > > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > > /usr/local/gd/lib.
> > > Make sure GD 2.0.16 or higher is compiled before calling
> > configure. You
> > > may als
> > > o get this error if you didn't specify the appropriate location
> > for one of
> > > GD's
> > > dependencies (freetype, libpng, libjpeg or libiconv).
> > > reports the same error when executing simple
> > > $. /configure
> > > the version of gd installed is gd 2.0.33
> > > aid please
> > > excuse the english
> Clint Johnson
> Refractions Research Inc.
> Cjohnson at refractions.net
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060424/83f6e264/attachment.html
