Antialiasing Again
Ken Boss
Ken.Boss at DNR.STATE.MN.US
Fri Apr 21 14:19:31 EDT 2006
Paul--
My apologies if this shows up twice, I sent it out yesterday but it appears to have gotten stuck in the network wires somewhere.
Anyway, I believe you need to:
1) use a 24-bit output image type (IMAGEMODE RGB (or RGBA))
2) set TRANSPARENCY ALPHA in the layer using antialiased lines
3) set ANTIALIAS TRUE in the STYLE element of the CLASS with antialiased lines
The following mapfile snippets enable antialiased county borders:
IMAGETYPE png24
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
LAYER
NAME counties
TYPE line
STATUS default
DATA "/r01/data/drs/data/gen/state/mn/bdry_counln2"
TRANSPARENCY alpha
SYMBOLSCALE 5000000
CLASS
STYLE
WIDTH 3
COLOR 1 1 1
ANTIALIAS true
END
END
END
Note that the bdry_counln2 shapefile referenced in the counties layer is a line shapefile. If I drop a polygon shapefile into the DATA element, and leave TYPE as line, the results are more or less the same. Alternatively, I can use a polygon shapefile, set TYPE to POLYGON, and use OUTLINECOLOR in place of COLOR in the STYLE element. In any case, I'm not sure that the POLYLINE type is supported any longer.
Finally, note that you can tweak the combination of STYLE->WIDTH and SYMBOLSCALE to modify line widths in your output images.
HTH,
--Ken
>>> Paul Dugas <paul at DUGAS.CC> 4/19/2006 10:59 AM >>>
I cannot seem to get MapServer-4.8.3 to draw antialiases lines. It is
working for polygons, but not for polylines. I got this working a long
time ago for another project but can't seem to this time. What I'm
really trying to accomplish is a smoothed two-tone line. I've tried
using ELLIPSE and CARTOLINE symbols with no success.
Would someone be willing to share a small working example I can start
from?
Thanks in advance,
Paul
Paul Dugas, Computer Engineer Dugas Enterprises, LLC
paul at dugas.cc phone: 404-932-1355 522 Black Canyon Park
http://dugas.cc fax: 866-751-6494 Canton, GA 30114 USA
On site at GDOT's W.Annex, 404-463-2860 x199
This e-mail and any attachments are confidential. If you receive
this message in error or are not the intended recipient, you should
not retain, distribute, disclose or use any of this information and
you should destroy the e-mail and any attachments or copies.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060421/a2b331a8/attachment.html
