shp2tile producing shp's with 1 object
Mark Dieterich
mdieterich at GMAIL.COM
Sat Apr 22 18:52:37 EDT 2006
I'm running shp2tile to break up the tiger shapefiles and consistently
getting one (or more, I'm not sure yet) tiled shapefiles that have only
a single feature in them. As a result, this is generating a bounding
box with either x or y coordinates that are the exact same value. I've
tried retiling with a variety of quadtree values and I always end up
with one particular shapefile that has a single feature in it. Bottom
line, this is killing some other code that currently checks for a "real"
bounding box.
So I'm curious whether:
a) This likely to be something with my underlying source data that's
causing this
b) Whether it's legit to end up with, basically a line, in one of the
tiled shapefiles or is this a bug
If the general consensus is this is not unexpected, then we can just
work around in the other code.
Thanks!
Mark
