JOIN Guidance {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sun Apr 23 13:58:23 EDT 2006
JOIN works only for query purposses. If you would like to classify objects
based on joined column, you should use ogr and sql. See
http://mapserver.gis.umn.edu/docs/howto/ogr_howto
4.2 Examples of Layer Definitions Using OGR Example 4.
Zoltan
On Sun, 23 Apr 2006, Paul Dugas wrote:
> I've been reading about the JOIN feature but I can't get it working yet.
> I'm trying to use a CSV file to add an attribute to features in a
> shapefile. Is this possible? If so, can someone provide a simple
> example?
> Thanks in advance,
> Paul
