install mapserver-4.8.3
Eduardo Arévalo
earevaloch at GMAIL.COM
Tue Apr 25 12:57:43 EDT 2006
hi Murat
My problem it is:
I execute the following one
$ ./configure --prefix=/usr/local/mapserver
--with-ogr=/usr/local/gdal/bin/gdal-config
--with-gdal=/usr/local/gdal/bin/gdal-config --with-apache=/usr/local/apache2
--with-httpd=/usr/local/apache2/bin --with-wfsclient --with-wmsclient
--enable-debug --with-curl-config=/usr/bin/curl-config
--with-proj=/usr/local/proj4 --with-tiff=/usr/local/tiff
--with-gd=/usr/local/ --with-jpeg=/usr/lib
--with-freetype=/usr/local/freetype2/bin/freetype-config
--with-postgis=/var/lib/pgsql/bin/pg_config
and it reports the following error to me
configure: error: Could not find gd.h or libgd.a/libgd.so in /usr/local/.
Make sure GD 2.0.16 or higher is compiled before calling configure. You may
als
o get this error if you didn't specify the appropriate location for one of
GD's
dependencies (freetype, libpng, libjpeg or libiconv).
please a solution idea
thanks
eduardo
2006/4/25, Murat Beyhan <beyhan at posta.deprem.gov.tr>:
> *I have installed 4.8.3 with gd-2.0.33.
> Murat
> On Mon, 24 Apr 2006 15:12:52 -0500, Eduardo Arévalo wrote*
> > ready aid:
> > who has installed mapserver-4.8.3 with gd-2.0.33 without problems I
> cannot
> > aid please
> > This message has been scanned for viruses and
> > dangerous content by *MailScanner* <http://www.mailscanner.info/>, and
> is
> > believed to be clean.
> Open WebMail Project (http://openwebmail.org)
> dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060425/7a18a891/attachment.html
