PNG24 output and GDAL dependency?
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 26 09:46:33 EDT 2006
Eijnden, B. van den (Bart) wrote:
> Hi list,
> we are trying to create a minimal PHP/Mapscript rpm, but are running into
> the issue that for 24 bits PNG output there is a dependency on GDAL. Why is
> this and can it be avoided somehow?
> Also, if we try to use 8 bit PNG (PC256 instead of RGB/RGBA), we get a
> segfault in PHP/Mapscript if GDAL is not compiled in. If GDAL is compiled
> in, all works fine.
Bart,
I am not aware of any reason why either would be the case. PNG24 output
should work fine without GDAL. Likewise I don't know why you run into the
problem with PC256. It is *possible* that with GDAL linked in an internal
copy of libpng is getting used instead of the system libpng, though I would
advise against using internal libpng in an RPM setup.
I would suggest trying to debug each of these problems to try and work out
what is happening.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
