PNG24 output and GDAL dependency?
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 26 10:33:06 EDT 2006
Eijnden, B. van den (Bart) wrote:
> Hi Frank,
> with respect to the first problem, Mapserver outputs an error message in
> this case:
> [26-Apr-2006 14:20:07] PHP Warning: [MapServer Error]:
> msDrawRasterLayerLow(): Attempt to render raster layer to IMAGEMODE RGB or
> RGBA but without GDAL available. 24bit output requires GDAL.
> Are you not aware of this requirement?
Bart,
Ah, I didn't realize you were trying to render input rasters to a 24bit
result. 24bit raster input is only supported with GDAL enabled. But
you should be able to render vector data to png24 without GDAL.
I would add that raster input capabilities are very limited without
GDAL enabled.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
