PNG24 output and GDAL dependency?
Frank Warmerdam
warmerdam at POBOX.COM
Wed Apr 26 12:36:41 EDT 2006
Bart van den Eijnden (OSGIS) wrote:
> Hi Frank,
> okay, basically what we are trying to do is have a minimal PHP/Mapscript
> which can only act as a WMS client. So the 24 bit images are already
> received from the WMS services, and only need to be merged into 1 image.
> But I guess there is no 'escaping' GDAL for that use case (btw I don't
> mean anything negative with escaping GDAL, but we want to have a really
> minimal setup for this).
Bart,
Well, it isn't implausible to imagine fixing up the built-in png, gif and
jpeg support to handle 24bit mode. They definately will not support
reprojection without a major overhaul. But Steve and I have generally not
felt that it is worth spending much effort on the old non-GDAL raster input
sources. So if you, or someone feels a minimal build for such a configuration
is valuable, there would be some development work to be done.
I quite understand about a minimal build. GDAL is a big whack of stuff. If
size is a major issue there are ways of building "pared down" GDAL's. But
that doesn't help much if simplicity is your main goal.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
