PNG24 output and GDAL dependency?
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Apr 26 12:17:01 EDT 2006
On a side note, maybe the error message should be changed to "24bit
input requires GDAL" instead of "24 bit output requires GDAL" ?
Best regards,
Bart
Frank Warmerdam wrote:
> Eijnden, B. van den (Bart) wrote:
>> Hi Frank,
>> with respect to the first problem, Mapserver outputs an error message in
>> this case:
>> [26-Apr-2006 14:20:07] PHP Warning: [MapServer Error]:
>> msDrawRasterLayerLow(): Attempt to render raster layer to IMAGEMODE
>> RGB or
>> RGBA but without GDAL available. 24bit output requires GDAL.
>> Are you not aware of this requirement?
> Bart,
> Ah, I didn't realize you were trying to render input rasters to a 24bit
> result. 24bit raster input is only supported with GDAL enabled. But
> you should be able to render vector data to png24 without GDAL.
> I would add that raster input capabilities are very limited without
> GDAL enabled.
> Best regards,
OSGIS, Open Source GIS
http://www.osgis.nl
