Variable Substitution in Filter expression
Ken Lord
kenlord at GMAIL.COM
Wed Apr 26 13:01:02 EDT 2006
Hi Benedict,
I do a variable substitution like yours, in my case I have it set in
my layer like this:
FILTERITEM "TYPE"
FILTER "%linearname%"
I think the problem is in your URL, try it without the quotes around the value.
Instead of:
street="SMITH%20ST"
use:
street=SMITH%20ST
Cheers,
Ken Lord
Vancouver BC
On 4/26/06, Benedict Marillier <Benedict.Marillier at dli.wa.gov.au> wrote:
> Hi All,
> I'm running mapserver 4.4.1.
> I've been trying to use a %variable% substitution to dynamically filter a
> shapefile. I have tried several combinations however none seem to work. The
> following filter works…
> FILTER ("[ROAD_NAME]" == "SMITH ST")
> However, attempting to use…
> FILTER ("[ROAD_NAME]" == "%street%")
> with the URL…
> mapserv.exe?map=variable.map&request=getmap&version=1.1.1&service=wms&layers=roads,copyright,lga,cadastre&BBOX=115.96538,-31.90127,115.96738,-31.89927&street="SMITH%20ST"
> does not.
> I've had no joy with any of the following either…
> FILTER "ROAD_NAME = '%street%'"
> or
> FILTERITEM 'ROAD_NAME'
> FILTER '%street%'
> Any suggestions appreciated.
> Cheers
> Ben
> This e-mail and any files transmitted with it are intended only for the use
> of the addressee(s). It may contain information that is confidential and
> privileged. If you are not an intended recipient, any use, interference
> with, disclosure, distribution or copying of this material is unauthorised
> and prohibited. If you receive this in error, please notify the author by
> Return email to the sender. Information in this message not relating to the
> official business of DLI shall be understood as neither given nor endorsed
> by it. While every care is taken, it is recommended that you scan any
> attachments for viruses. DLI liability is limited to re-supplying affected
> attachments.
> PLEASE NOTE: All dola.wa.gov.au and vgo.wa.gov.au email addresses have been
> decommissioned. These have been replaced by dli.wa.gov.au addresses. Please
> ensure that your records are updated to reflect this change. Further
> information can be obtained by contacting our service desk on 92737533 or
> emailing Servicedesk at dli.wa.gov.au
