Variable Substitution in Filter expression
Benedict Marillier
Benedict.Marillier at DLI.WA.GOV.AU
Wed Apr 26 03:26:29 EDT 2006
Hi All,
I'm running mapserver 4.4.1.
I've been trying to use a %variable% substitution to dynamically filter
a shapefile. I have tried several combinations however none seem to
work. The following filter works...
FILTER ("[ROAD_NAME]" == "SMITH ST")
However, attempting to use...
FILTER ("[ROAD_NAME]" == "%street%")
with the URL...
mapserv.exe?map=variable.map&request=getmap&version=1.1.1&service=wms&la
yers=roads,copyright,lga,cadastre&BBOX=115.96538,-31.90127,115.96738,-31
.89927&street="SMITH%20ST"
does not.
I've had no joy with any of the following either...
FILTER "ROAD_NAME = '%street%'"
or
FILTERITEM 'ROAD_NAME'
FILTER '%street%'
Any suggestions appreciated.
Cheers
Ben
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this in error, please notify the author by Return email to the sender. Information in this message not relating to the official business of DLI shall be understood as neither given nor endorsed by it. While every care is taken, it is recommended that you scan any attachments for viruses. DLI liability is limited to re-supplying affected attachments.
PLEASE NOTE: All dola.wa.gov.au and vgo.wa.gov.au email addresses have been decommissioned. These have been replaced by dli.wa.gov.au addresses. Please ensure that your records are updated to reflect this change. Further information can be obtained by contacting our service desk on 92737533 or emailing Servicedesk at dli.wa.gov.au
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060426/66b95b8d/attachment.html
