MapServer with MapInfo (WFS)
Francesco Antognini
fantognini at GMAIL.COM
Fri Apr 28 17:01:47 EDT 2006
Hello
I think I'm stuck on a similar problem and maybe I can give further
information.
I'm basically doing the same thing, testing the WFS service with Mapinfo and
while a GetFeature issued from a browser works fine, the same thing done
from Mapinfo doesn't work. (WMS works fine)
After poking around with various tools, I start to believe this might be a
POST vs. GET issue.
A browser works with GET requests and appends parameters to the URL,
including the vital map path. This works fine.
However MapServer in GetCapabilities advertises the POST services too, and
some clients will indeed send their requests as POST of XML data. Mapinfo
does it for sure.
Now: no matter what workaround I use to bring the map into the request, this
will still appear as an URL parameter, while the rest of the request is
posted as XML.
My feeling is that mapserv.exe gets confused about this and thinks that this
is really a GET request and starts complaining in various ways about lack of
parameters.
If that's the real issue, then I can think of some workarounds. The first
being how to reinject the map into the request without using a URL
parameter. Any idea?
Hope I haven't been too confusing
TIA
F.Antognini
On 4/26/06, Léveillé, James <James.Leveille at mtq.gouv.qc.ca> wrote:
> Hi all,
> I'm trying to test MapServer (v 4.8.3), the WFS service, with MapInfo (v
> 8.0) and keep having this error message:
> *"The WFS Server returned data which was neither in the requested format
> nor a recognized WFS service exception : POST body is short.*
> *In response to a DescribeFeatureType request, the WFS Server returned an
> invalid feature type."*
> The GetCapabilities looks fine, and the GetFeature works fine with IE ...
> Here is my (simple) MapFile.
> THANKS A LOT !!!
> <snip>
> </snip>
> *James Léveillé*
> *Intélec Géomatique*
> 420, boul. Charest Est
> Bureau 400
> Québec (QC), Canada
> G1K 8M4
> Intélec Géomatique: 418.687.5000
> MTQ: 418.380.2005 (#227)
Francesco Antognini
Computer Consultant
Switzerland
fantognini at gmail.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060428/61efa9e0/attachment.html
