Edit shape file in web MapServer application
Paolo Corti
pcorti at GMAIL.COM
Tue Aug 1 07:12:15 EDT 2006
Hello
I developed a simple application to edit shapefile with mapscript
this is the sample code to add a point with some attributes to a point
shapefile (c#):
private void AddPoint(Double x, Double y, String activeLayer, String[,]
fieldValues)
//check: this action is valid only for point shapefiles
pointObj point = pixel2point(new pointObj(x,y,0,0)); //conver the image
point in map point
String shapeFullPath = map.shapepath + "\\" + activeLayer + ".shp";
shapefileObj shapefile = new shapefileObj(shapeFullPath,-2);
if(shapefile.type!=(int)mapscript.MS_SHAPEFILE_POINT)
//notify action
lblInfo.Text = "This action can be performed only on point shapefiles.";
else
/*Alternative way to insert a point in the shapefile using shapeObj:
//create line to store point
lineObj line = new lineObj();
line.add(point);
//create shape
shapeObj shape = new shapeObj((int)MS_SHAPE_TYPE.MS_SHAPE_POINT);
shape.add(line);
//add shape to shapefile
shapefile.add(shape;
shapefile.addPoint(point);
//add record for dbf table
OleDbConnection cn = new
OleDbConnection(@"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" +
map.shapepath + ";Extended Properties=dBASE IV;User ID=Admin;Password=");
cn.Open();
OleDbCommand com = cn.CreateCommand();
//get field list and value list
String fieldList = "";
String valueList = "";
for(int i=0; i<(fieldValues.Length/2); i++)
fieldList = fieldList + fieldValues[i,0];
valueList = valueList + "'" + fieldValues[i,1] + "'";
if(i<((fieldValues.Length/2)-1))
fieldList = fieldList + ", ";
valueList = valueList + ", ";
com.CommandText = "INSERT INTO " + activeLayer + " (" + fieldList + ")
VALUES(" + valueList + ")";
com.CommandType = CommandType.Text;
com.ExecuteNonQuery();
cn.Close();
//notify action
lblInfo.Text = "Point added (" + shapefile.numshapes.ToString() + "
features in shapefile).";
shapefile.Dispose();
This is what I want to ask here, as I am new to mapscript and MapServer: is
it safe to edit shapefile online, can be any thread or cuncurrency issues?
At least in my ESRI experience with ArcIMS I know that they don't let you
edit a shapefile if it is served on the web (ArcIMS locks it). If you need
to edit data you need ArcSDE.
So it is strange to me that MapServer give you this edit possibilites, but
maybe (I couldn't find anywhere) is it safe to use this capacities only for
standalone apps?
Or should i convert my data to MySQL or PostGIS?
thank you
Paolo
View this message in context: http://www.nabble.com/Edit-shape-file-in-web-MapServer-application-tf2032930.html#a5592464
Sent from the Mapserver - User forum at Nabble.com.
