panning and zoomin and out, and ect
Brent Pedersen
bpederse at NATURE.BERKELEY.EDU
Wed Aug 2 11:04:09 EDT 2006
hi, can you give more info on how it is not working?
what happens?
you may want to check what x and y are coming out as.
often + will concatenate numbers instaed of adding.
also, are you sure you want x and y to go negative as you
have made them in 'nw' for example?
i would try
if(direction=='nw'){
x = 1;
y = 1;
which i think should recenter you on the upper left corner of the map.
On Wed, 2 Aug 2006, Albert Anderson wrote:
> Hi,
> I put my code with this email "hoping" for more than just it maybe in your map file or hidden variables thats all.
> Thanks,
> Albert
> Luis Treviño <ltrevinoh at gmail.com> wrote: Albert:
> Maybe the problem is in your map file or in the hidden variables of your template.
> 2006/8/1, Albert Anderson <bart_doggers at yahoo.com>: Hi,
> I tried that code. I didnt get it to work. Here is my code. Can you see if I need to do something else? What else do I need?
> </script>
> <!-- Panning Javascript here -->
> <script language="javascript" type="text/javascript">
> var mapheight = 417;
> var mapwidth = 309;
> var pansize = 0.75;
> function pan(direction) {
> var x,y;
> if(direction== 'n') {
> x = (309-1)/2.0;
> y = 0 - (417 * pansize)/2.0;
> } else if(direction== 'nw') {
> x = 0 - (309 * pansize)/2.0;
> y = 0 - (309 * pansize)/2.0;
> } else if(direction== 'ne') {
> x = (309-1) + (309 * pansize)/2.0;
> } else if(direction== 's') {
> x = (309-1)/2.0;
> y = (417-1) + (417 * pansize)/2.0;
> } else if(direction== 'sw') {
> } else if(direction== 'se') {
> } else if(direction== 'e') {
> y = (417-1)/2.0;
> } else if(direction== 'w') {
> y = (417-1)/2.0;
> document.mapserv.imgxy.value = x + " " + y;
> document.mapserv.submit();
> </script>
> <TABLE width="368"
> HEIGHT="460" BORDER="0" align="left" CELLPADDING="0" CELLSPACING="0">
> <TBODY>
> <TR>
> <TD width="29" height="23" ALIGN="left"
> VALIGN="top" BGCOLOR="#e7a500"><a href="javascript:pan('nw')"><img src="../images/cornerarrow5.gif" alt="pan nw" width="25" height="25" style="border-style:none"></a></TD>
> <TD ALIGN="center" BGCOLOR="#e7a500"
> VALIGN="top"> <div align="center"><a href="javascript:pan('n')"><img src="../images/cornerarrow2.gif" alt="pan north" width="25" height="25" style="border-style:none"></a></div></TD>
> <TD width="30" ALIGN="right"
> VALIGN="top" BGCOLOR="#e7a500"><a href="javascript:pan('ne')"><img src="../images/cornerarrow6.gif" alt="pan ne" width="25" height="25" style="border-style:none"></a></TD>
> </TR>
> <TR>
> <TD ALIGN="LEFT" BGCOLOR="#e7a500"
> VALIGN="MIDDLE"><a href="javascript:pan('w')"><img src="../images/cornerarrow1.gif" alt="pan west" width="25" height="25" style="border-style:none"></a></TD>
> <TD CLASS="mapappmidaln" ALIGN="center"
> HEIGHT="413" VALIGN="MIDDLE" WIDTH="309">
> <!-- calling for map here -->
> <input name="img" type="image" src="[img]" WIDTH="309" HEIGHT="417" BORDER="1" /></TD>
> <TD ALIGN="right" BGCOLOR="#e7a500"
> VALIGN="MIDDLE"><div align="left"><a href="javascript:pan('e')"><img src="../images/cornerarrow3.gif" alt="pan east" width="25" height="25" style="border-style:none"></a></div></TD>
> </TR>
> <TR>
> <TD height="21" ALIGN="left"
> VALIGN="bottom" BGCOLOR="#e7a500"><a href="javascript:pan('sw')"><img src="../images/cornerarrow8.gif" alt="pan sw" width="25" height="25" style="border-style:none"></a></TD>
> VALIGN="bottom"> <div align="center"><a href="javascript:pan('s')"><img src="../images/cornerarrow3gif.gif" alt="pan south" width="25" height="25" style="border-style:none"></a></div></TD>
> VALIGN="bottom"><a href="javascript:pan('se')"><img src="../images/cornerarrow7.gif" alt="pan se" width="25" height="25" style="border-style:none"></a></TD>
> </table>
> Luis Treviño <ltrevinoh at GMAIL.COM> wrote:
> 2006/7/21, Albert Anderson <bart_doggers at yahoo.com>: Hi,
> I figure out my images. Does anyone have a _java script for using a image for panning. I have images set for the corners of my map. I want to use them to pan.
> You can use something like this, you have to handle your width and height of your image:
> alto = height, ancho = width.
> function paneo(direccion,alto,ancho) {
> var x,y;
> var pansize = 0.75;
> if(direccion == 'n') {
> x = (ancho-1)/2.0;
> y = 0 - (alto * pansize)/2.0;
> } else if(direccion == 'nw') {
> x = 0 - (ancho * pansize)/2.0;
> y = 0 - (ancho * pansize)/2.0;
> } else if(direccion == 'ne') {
> x = (ancho-1) + (ancho * pansize)/2.0;
> } else if(direccion == 's') {
> x = (ancho-1)/2.0;
> y = (alto-1) + (alto * pansize)/2.0;
> } else if(direccion == 'sw') {
> } else if(direccion == 'se') {
> } else if(direccion == 'e') {
> y = (alto-1)/2.0;
> } else if(direccion == 'w') {
> y = (alto-1)/2.0;
> Anyother question, is there a _java script for images to zoom-in and out?
> you can use the zoomdir and the zoom values within your template, like:
> <input type="hidden" name="zoom" value="-2">
> <input type="hidden" name="zoomdir" value="-1">
> for a zoom out., so you can use radio buttons to manage this values
> One more question, I have a refresh button and pan radio button, then we I click refresh to take a layer off it moves the projective image. Why? But when I am on zoomin radio button and click refresh it acts like its panning? Why?
> Thanks,
> Albert
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
> Hope this helps.
> Regards,
> Luis
> Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
> Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1¢/min.
