Java Mapscript
    Ryan Ollerenshaw
    ollerery at ENGR.ORST.EDU
    Thu Aug  3 14:28:10 PDT 2006
Alejandro Rico wrote:
> Hi Ryan!!
> You must add the file libmapscript.so to your tomcat shared folder.
> Check http://mapserver.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55
> <http://mapserver.gis.umn.edu/docs/howto/java_mapscript_Tomcat_55>,
> here explain the correct configuration for use javamapscript
Thanks for the help but still no luck,
I only see a libmapscript.so in the PHP section of my MapServer download
directory structure.  But i used it anyway and copied the directory
structure shown on the link that you sent.  But i am still getting:
java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
> On 8/3/06, *Ryan Ollerenshaw* <ollerery at engr.orst.edu
> <mailto:ollerery at engr.orst.edu>> wrote:
>     I am trying to use MapServer's java Mapscript and keep getting the
>     following error:
>     Java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
>     I have added mapscript.jar to my WEB-INF/lib directory, but i am not
>     sure what else i should do.  I am using eclipse with the Tomcat
>     plug in,
>     so i have also added the .jar file to eclipse but i dont think that
>     makes a difference when using tomcat.
>     Here is my java code:
>     import java.io.*;
>     import javax.servlet.*;
>     import javax.servlet.http.* ;
>     import edu.umn.gis.mapscript.*;
>     public class MapServerTest extends HttpServlet {
>         public void doGet ( HttpServletRequest request,
>     HttpServletResponse
>     response )
>             throws ServletException, IOException    {
>             response.setContentType("text/html");
>             PrintWriter out = response.getWriter();
>             System.loadLibrary("mapscript");
>             out.println("<html>");
>             out.println("<head><title>Hello World!</title></head>");
>             out.println("<body>");
>             out.println("<h1>aa Hello, World !</h1>");
>             //mapObj map = new
>     mapObj("var/www/html/mapserver/htdocs/display.map");
>         }// end doGet
> Alejandro Rico
More information about the MapServer-users
