Java Mapscript
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Thu Aug 3 17:25:45 EDT 2006
Alejandro Rico wrote:
> ok, i forgot that at the beginning of the startup script
> (/..../apache-tomcat../bin/startup.sh) of your tomcat
> installation, you must write a line like
> export LD_LIBRARY_PATH= path_where_you_have_libmapscript.so
Still no luck i added the following to my startup.sh, i was not to sure
what way is correct so i added two lines:
export LD_LIBRARY_PATH=/etc/tomcat5/shared/lib
exec `export LD_LIBRARY_PATH=/etc/tomcat5/shared/lib`
