Extents defined in mapfile versus those returned from
GetCapabilities WMS request
Geoff Dibley
Geoff.Dibley at GA.GOV.AU
Fri Aug 4 00:08:42 EDT 2006
Hi there,
I have a mapfile that defines an extent and projection as follows;
EXTENT -2200000 -4700000 2000000 -1500000
PROJECTION
"init=epsg:3112"
# epsg:3112 (formerly 18001) is the same as the following:
# "proj=lcc"
# "ellps=WGS84"
# "lat_1=-18d"
# "lat_2=-36d"
# "lat_0=0d"
# "lon_0=134d"
# "x_0=0d"
# "y_0=0d"
END
Map Name, Projection, and required layer metadata (wms_title,
wms_onlineresource, and wms_srs) are all set as per the Mapserver WMS Server
How to.
Layer Name, Projection and metadata are set (wms_title) s per the Mapserver
WMS Server How to.
This all works OK - but I'm confused as to where the LatLonBoundingBox and
Bounding Box values in the GetCapabilities statement below are coming from;
<Layer queryable="1" opaque="0" cascaded="0">
<Name>cities</Name>
<Title>Cities and towns of Australia by type.</Title>
<SRS>EPSG:3112</SRS>
<LatLonBoundingBox minx="-179.844" miny="-59.4692" maxx="179.937"
maxy="22.971" />
<BoundingBox SRS="EPSG:3112"
minx="-1.03618e+07" miny="-6.85014e+06"
maxx="5.04576e+06" maxy="-8863.8" />
Are the bounding box x,y the actual extents (in epsg:3112 units) calculated
by Mapserver for that layer ?
How does this relate to the extents defined in the top level of the mapfile
(getmap requests on the layer limit themselves to these extents if no bbox is
specified) ?
Where do the latlonbounding box values come from - are they simply calculated
in Mapserver by converting the epsg:3112 co-ordinates tom lat/long ?
Any thoughts gratefully received !
Cheers,
Geoff
