Tomcat help
Simon Haddon
simon at SIBERN.COM.AU
Fri Aug 4 02:52:16 EDT 2006
I think that yo will find that it is finding the jar file. The problem is
that mapscript.jar can't find mapscript.so . You need to make sure that
the shared library is in the tomcat library path as well. You might need
to define of extend LD_LIBRARY_PATH or maybe use java.library.path . Would
need to check
Cheers,
Simon Haddon
> I am able to compile a java mapscript file from the command line using:
> javac -classpath ./mapscript.jar MapServerTest.java
> But when i try to turn my code into a servelt and run it over Tomcat i
> keep getting:
> java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
> I have tried adding:
> export CLASSPATH=./mapscript.jar
> to my ./startup.sh file but that does not seem to help. Am i missing a
> setting somewhere, why cant Tomcat find the .jar file? I have it in the
> same directory as my .java file and also in /common/lib and /shared/lib
> Thank you for any help that you can provide
