Tomcat help
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Thu Aug 3 18:50:12 EDT 2006
I am able to compile a java mapscript file from the command line using:
javac -classpath ./mapscript.jar MapServerTest.java
But when i try to turn my code into a servelt and run it over Tomcat i
keep getting:
java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
I have tried adding:
export CLASSPATH=./mapscript.jar
to my ./startup.sh file but that does not seem to help. Am i missing a
setting somewhere, why cant Tomcat find the .jar file? I have it in the
same directory as my .java file and also in /common/lib and /shared/lib
Thank you for any help that you can provide
