FW: Asking about driver
Fawcett, David
David.Fawcett at STATE.MN.US
Fri Aug 4 08:55:05 EDT 2006
I got this as a comment to the OGR MSQL Howto on the MapServer site. I am passing it on to the list for a wider group of eyes.
Ahmed,
Looking at the error, it appears that you have not changed the OVF file to reflect the name, password, etc. of your database setup. It would help the list help you if you posted the text of your ovf file to the list.
David.
-----Original Message-----
From: ayaha2001 at yahoo.fr [mailto:ayaha2001 at yahoo.fr]
Sent: Friday, August 04, 2006 6:14 AM
To: Fawcett, David
Subject: Asking about driver
You are receiving this mail because Ayadi Ahmed (ahmed), ayaha2001 at yahoo.fr is sending feedback about content created by you at http://mapserver.gis.umn.edu/docs/howto/ogrmysql.
The message sent was:
I have a problem when I want to use orginfo to connect to mysql database. 'orginfo' n'est pas reconnu en tant que commande interne ou externe, un programme exécutable ou un fichier de commandes. C:\wamp\tools\gdal-ogr>ogrinfo aqidata.ovf ERROR 4: Update access not supported for VRT datasources. ERROR 1: Failed to open datasource `MYSQL:aqiTest,user=root,password=,host=127. .0.1,port=3306,tables=testdata'. FAILURE: Unable to open datasource `aqidata.ovf' with the following drivers. -> ESRI Shapefile -> UK .NTF -> SDTS -> TIGER -> S57 -> MapInfo File -> DGN -> VRT -> AVCBin -> REC -> Memory -> CSV -> GML -> ODBC -> PGeo -> FMEObjects Gateway Thanks.
MapServer Website
