shp2img in latest mapserver version?
M.L. Jackson
mljacks2 at HOTMAIL.COM
Fri Aug 4 10:36:45 EDT 2006
Does the latest version of mapserver (4.8.4) include a shp2img executable?
I was browsing the folders and could not find it anywhere. Maybe I
downloaded the wrong version. Thanks.
>From: Steve Lime <Steve.Lime at DNR.STATE.MN.US>
>Reply-To: Steve Lime <Steve.Lime at DNR.STATE.MN.US>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] What does this error message mean?
>Date: Thu, 3 Aug 2006 15:27:14 -0500
>I don't know that it's an update issue, the choice of version was
>interesting though.
>I'm gonna look through the lexer source code to see if there are any clues
>there and will report back.
>Steve
> >>> "M.L. Jackson" <mljacks2 at hotmail.com> 8/3/2006 1:51:34 PM >>>
>Honestly, I downloaded this version as an update a while back and I
>remember
>it being a pain so I haven't been looking forward to updating again. I
>continued this project from someone else and always have to figure out
>where
>all the files are located and what I actually need to download. I guess I
>am now forced to update.
>The reason I posted the code snippet is that the error only seems to show
>when I add this code to my Java bean.
>Thanks for your replies.
> >From: "Steve Lime" <Steve.Lime at dnr.state.mn.us>
> >To: <mljacks2 at hotmail.com>, <mapserver-users at lists.umn.edu>
> >Date: Wed, 02 Aug 2006 17:56:49 -0500
> >Why are you running an old, not to mention beta, version?
> >That aside I don't see code here that would even invoke the lexer. That
> >only happens with mapfile parsing and expression evaluation.
> >Steve
> > >>> "M.L. Jackson" <mljacks2 at hotmail.com> 08/02/06 2:54 PM >>>
> >I'm on a Windows machine running mapscript 4.6.0-beta1.
> >Shp2img runs on it fine. The map file is a map of the United States of
> >America with a rivers layer, states layer, and wms layer.
> >I'm running a JSP script. Yes, I have run a similar script on Tomcat.
> >The
> >script prints an interactive map legend using a Java Bean print method
> >call.
> >The Java Bean method looks like this:
> >public String makeLegend()
> >String layerName = "";
> >int layerCount = map.getNumlayers();
> >String legend = "";
> >//check the layer for a space which will cause problems and display
> >error
> >message
> >for(int i = 0; i < layerCount; i++)
> > layerName = map.getLayer(i).getName();
> > if(layerName.contains(" ")){
> >legend += "<br><br><i><b><font color = red size = 2>The layer name \"" +
> >layerName +
> > "\" contains a space character and
> >will not function
> >correctly!!<br>" +
> > "Find the layer in the map file
> >and remove the space,
> >then " +
> > "reload the
> >application.</font></b></i>";
> > return legend;
> >//generates html for check boxes
> >legend = " <form name = \"legendForm\">";
> >legend += "\n <input type = \"checkbox\" onclick =
> >handleBoxes(\"" +
> >layerName + "\")" +
> > " name = \"" + layerName +
> >"box\" checked>" + layerName.replace("_", "
> >") + "</input><br><br>";
> >legend += "\n </form>";
> >return legend;
> >Hope this is somewhat clear. Thanks.
> > >To: "M.L. Jackson" <mljacks2 at hotmail.com>,
> > ><MAPSERVER-USERS at lists.umn.edu>
> > >Date: Wed, 02 Aug 2006 14:15:45 -0500
> > >Hmmm... Haven't seen that one before. I've found very little on Google
> > >with regards to the
> > >error. Something tells me it has to do with something like an empty
> > >file however I tried doing
> > >that locally and got a more appropriate error. So, we'll need more
> > >information.
> > >- what platform? what version?
> > >- what does the mapfile look like? can you run shp2img on it?
> > >- have you run this or a similar script successfully under tomcat?
> > >Steve
> > > >>> "M.L. Jackson" <mljacks2 at HOTMAIL.COM> 8/2/2006 1:50:57 PM >>>
> > >What does this mean? This message is generated when I try to run my
> > >java
> > >mapscript application on Tomcat.
> > >"fatal flex scanner internal error--end of buffer missed"
> > >_________________________________________________________________
> > >Express yourself instantly with MSN Messenger! Download today - it's
> > >FREE!
> > >http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
> >FREE!
>Dont just search. Find. Check out the new MSN Search!
>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Express yourself instantly with MSN Messenger! Download today - it's FREE!
