shp2img in latest mapserver version?
M.L. Jackson
mljacks2 at HOTMAIL.COM
Fri Aug 4 14:16:58 EDT 2006
Never mind that question. I know I have to compile it to get the
executables.
>From: "M.L. Jackson" <mljacks2 at HOTMAIL.COM>
>Reply-To: "M.L. Jackson" <mljacks2 at HOTMAIL.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: [UMN_MAPSERVER-USERS] shp2img in latest mapserver version?
>Date: Fri, 4 Aug 2006 09:36:45 -0500
>Does the latest version of mapserver (4.8.4) include a shp2img executable?
>I was browsing the folders and could not find it anywhere. Maybe I
>downloaded the wrong version. Thanks.
>>From: Steve Lime <Steve.Lime at DNR.STATE.MN.US>
>>Reply-To: Steve Lime <Steve.Lime at DNR.STATE.MN.US>
>>Subject: Re: [UMN_MAPSERVER-USERS] What does this error message mean?
>>Date: Thu, 3 Aug 2006 15:27:14 -0500
>>I don't know that it's an update issue, the choice of version was
>>interesting though.
>>I'm gonna look through the lexer source code to see if there are any clues
>>there and will report back.
>>Steve
>> >>> "M.L. Jackson" <mljacks2 at hotmail.com> 8/3/2006 1:51:34 PM >>>
>>Honestly, I downloaded this version as an update a while back and I
>>remember
>>it being a pain so I haven't been looking forward to updating again. I
>>continued this project from someone else and always have to figure out
>>where
>>all the files are located and what I actually need to download. I guess I
>>am now forced to update.
>>The reason I posted the code snippet is that the error only seems to show
>>when I add this code to my Java bean.
>>Thanks for your replies.
>> >From: "Steve Lime" <Steve.Lime at dnr.state.mn.us>
>> >To: <mljacks2 at hotmail.com>, <mapserver-users at lists.umn.edu>
>> >Date: Wed, 02 Aug 2006 17:56:49 -0500
>> >Why are you running an old, not to mention beta, version?
>> >That aside I don't see code here that would even invoke the lexer. That
>> >only happens with mapfile parsing and expression evaluation.
>> >Steve
>> > >>> "M.L. Jackson" <mljacks2 at hotmail.com> 08/02/06 2:54 PM >>>
>> >I'm on a Windows machine running mapscript 4.6.0-beta1.
>> >Shp2img runs on it fine. The map file is a map of the United States of
>> >America with a rivers layer, states layer, and wms layer.
>> >I'm running a JSP script. Yes, I have run a similar script on Tomcat.
>> >The
>> >script prints an interactive map legend using a Java Bean print method
>> >call.
>> >The Java Bean method looks like this:
>> >public String makeLegend()
>> >String layerName = "";
>> >int layerCount = map.getNumlayers();
>> >String legend = "";
>> >//check the layer for a space which will cause problems and display
>> >error
>> >message
>> >for(int i = 0; i < layerCount; i++)
>> > layerName = map.getLayer(i).getName();
>> > if(layerName.contains(" ")){
>> >legend += "<br><br><i><b><font color = red size = 2>The layer name \"" +
>> >layerName +
>> > "\" contains a space character and
>> >will not function
>> >correctly!!<br>" +
>> > "Find the layer in the map file
>> >and remove the space,
>> >then " +
>> > "reload the
>> >application.</font></b></i>";
>> > return legend;
>> >//generates html for check boxes
>> >legend = " <form name = \"legendForm\">";
>> >legend += "\n <input type = \"checkbox\" onclick =
>> >handleBoxes(\"" +
>> >layerName + "\")" +
>> > " name = \"" + layerName +
>> >"box\" checked>" + layerName.replace("_", "
>> >") + "</input><br><br>";
>> >legend += "\n </form>";
>> >return legend;
>> >Hope this is somewhat clear. Thanks.
>> > >To: "M.L. Jackson" <mljacks2 at hotmail.com>,
>> > ><MAPSERVER-USERS at lists.umn.edu>
>> > >Date: Wed, 02 Aug 2006 14:15:45 -0500
>> > >Hmmm... Haven't seen that one before. I've found very little on Google
>> > >with regards to the
>> > >error. Something tells me it has to do with something like an empty
>> > >file however I tried doing
>> > >that locally and got a more appropriate error. So, we'll need more
>> > >information.
>> > >- what platform? what version?
>> > >- what does the mapfile look like? can you run shp2img on it?
>> > >- have you run this or a similar script successfully under tomcat?
>> > >Steve
>> > > >>> "M.L. Jackson" <mljacks2 at HOTMAIL.COM> 8/2/2006 1:50:57 PM >>>
>> > >What does this mean? This message is generated when I try to run my
>> > >java
>> > >mapscript application on Tomcat.
>> > >"fatal flex scanner internal error--end of buffer missed"
>> > >_________________________________________________________________
>> > >Express yourself instantly with MSN Messenger! Download today - it's
>> > >FREE!
>> > >http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
>> >FREE!
>>Dont just search. Find. Check out the new MSN Search!
>>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
>Express yourself instantly with MSN Messenger! Download today - it's FREE!
FREE pop-up blocking with the new MSN Toolbar get it now!
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
