Mapserver returns blank pages
antti siukola
siukola.antti at GMAIL.COM
Mon Aug 7 04:26:26 EDT 2006
Hi!
Problem seems to be solved after abandoning anti-aliasing and
configuring mapserver with threads.
Cheers!
On 7/20/06, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> I presume you are running php as shared module, right?
> If so recompile with this configure flag: --with-threads and then make
> sure you read the thread safety FAQ:
> http://mapserver.gis.umn.edu/docs/faq/thread_safety
> If you plan to use unsafe components (like cartoline symbols) switch
> php to cgi mode (and then you can avoid using the --with-threads
> option).
> HTH,
> Umberto
> On 7/20/06, antti siukola <siukola.antti at gmail.com> wrote:
> > Hello!
> > Production:
> > Redhat AS4 Upd 3
> > Mysql 5.0.21
> > Apache 2.2.2 with mod_php
> > Mapserver 4.8.3
> > PHP 5.14
> > Gdal 1.3.2
> > Development:
> > Ubuntu breezy
> > MySQL 5.0.18
> > Apache 2.0.55 with mod_php
> > MapServer 4.8.4
> > PHP PHP 5.0.5-2ubuntu1.2
> > Gdal 1.3.2
> > MapServer configure:
> > --with-ogr --with-gdal --with-tiff --with-gd --with-jpeg
> > --with-php=/usr/include/php5/ --with-odbc --with-httpd --with-proj
> > It doesn't matter which on of the servers it is the problems are the same.
> > And here is a sample of one of the map files:
> > MAP
> > NAME "name"
> > FONTSET fontset.txt
> > STATUS ON
> > EXTENT 34083.890 75139.631 40587.098 79917.784
> > SIZE 500 367
> > SYMBOLSET ../etc/symbols.sym
> > UNITS METERS
> > IMAGECOLOR 240 240 240
> > WEB
> > LOG "/mapserver.log"
> > IMAGEPATH "/tmp/ms_tmp/"
> > IMAGEURL "/ms_tmp/"
> > MINSCALE 3000
> > MAXSCALE 50000
> > END # WEB ends
> > IMAGETYPE JPEG
> > OUTPUTFORMAT
> > NAME png
> > DRIVER "GD/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE PC256
> > EXTENSION "png"
> > END
> > OUTPUTFORMAT
> > NAME png24
> > DRIVER "GD/PNG"
> > IMAGEMODE RGBA
> > EXTENSION "png"
> > END
> > OUTPUTFORMAT
> > NAME jpeg
> > DRIVER "GD/JPEG"
> > FORMATOPTION "QUALITY=87"
> > MIMETYPE "image/jpeg"
> > IMAGEMODE RGB
> > EXTENSION "jpg"
> > END
> > OUTPUTFORMAT
> > NAME GTiff
> > DRIVER "GDAL/GTiff"
> > MIMETYPE "image/tiff"
> > IMAGEMODE RGB
> > EXTENSION "tif"
> > END
> > # Start of legend
> > LEGEND
> > KEYSIZE 18 12
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > COLOR 0 0 89
> > END
> > STATUS ON
> > END
> > # Start of scalebar
> > SCALEBAR
> > IMAGECOLOR 255 255 255
> > LABEL
> > COLOR 0 0 0
> > SIZE SMALL
> > END
> > SIZE 300 5
> > COLOR 19 100 133
> > BACKGROUNDCOLOR 71 153 71
> > UNITS meters
> > INTERVALS 5
> > STATUS ON
> > END
> > QUERYMAP
> > STYLE HILITE
> > COLOR 255 240 0
> > END
> > LAYER
> > NAME "name"
> > DATA "data/raster/image.tif"
> > TYPE RASTER
> > STATUS OFF
> > END #LAYER
> > LAYER
> > NAME name
> > TYPE POLYGON
> > DATA /url/to/shp/shp
> > STATUS OFF
> > CLASS
> > NAME "name"
> > COLOR 255 255 255
> > END
> > END # Layer shapefile ends
> > LAYER
> > NAME name
> > TYPE POLYGON
> > STATUS OFF
> > CONNECTIONTYPE OGR
> > CONNECTION "/url/to/tab.TAB"
> > LABELITEM "name"
> > # STYLEITEM "AUTO"
> > CLASS
> > NAME "name"
> > COLOR 216 176 255
> > LABEL
> > TYPE TRUETYPE
> > ANTIALIAS TRUE
> > FONT FreeSans
> > COLOR 0 0 0
> > OUTLINECOLOR 220 220 220
> > SIZE 8
> > OFFSET 0 2
> > buffer 2
> > END #label
> > END
> > END # Layer ends
> > LAYER
> > NAME name
> > TYPE LINE
> > STATUS OFF
> > CONNECTIONTYPE OGR
> > LABELITEM "text"
> > CLASS
> > NAME "name"
> > LABEL
> > TYPE TRUETYPE
> > ANTIALIAS TRUE
> > FONT FreeSans
> > COLOR 255 255 255
> > OUTLINECOLOR 0 0 0
> > SIZE 10
> > ANGLE AUTO
> > POSITION UC
> > OFFSET 0 2
> > buffer 2
> > END #label
> > END #class
> > END # Layer test ends
> > LAYER
> > NAME name
> > TYPE LINE
> > STATUS OFF
> > CONNECTIONTYPE OGR
> > STYLEITEM "AUTO"
> > CLASS
> > NAME "name"
> > END
> > END # Layer ends
> > END # MAP ends
> > Cheers!
> > > Antti,
> > > please tell us more:
> > > - version of mapserver
> > > - how you built it (yourself or picked one from where)
> > > - if you built it yourself the configure flags you used
> > > - are you using php as a shared module or as a cgi?
> > > - version of apache, php and linux (uname -a)
> > > Can you post the map file to the list?
> > > Regards,
> > > Umberto
> > > On 6/13/06, antti siukola <siukola.antti at gmail.com> wrote:
> > > > Hi!
> > > > Every time MapServer returns a blank page I find "[notice] child pid
> > > > xxxx exit signal Segmentation fault (11)" from apache's error_log. Any
> > > > thoughts? Blank pages are returned randomly.
> > > > AnttiS
