Loading ECW data
antti siukola
siukola.antti at GMAIL.COM
Tue Aug 8 02:36:08 EDT 2006
Hi!
I compiled ER Mappers ECW SDK and GDAL against it and even re-compiled
MapServer but still get the same error: ecw is not an EPPL file.
$ gdalinfo --format ecw gives me:
Format Details:
Short Name: ECW
Long Name: ERMapper Compressed Wavelets
Extension: ecw
Help Topic: frmt_ecw.html
Supports: CreateCopy() - Create dataset by copying another.
Creation Datatypes: Byte
<CreationOptionList>
<Option name="TARGET" type="float" description="Compression Percentage"/>
<Option name="PROJ" type="string" description="ERMapper Projection Name"/>
<Option name="DATUM" type="string" description="ERMapper Datum Name"/>
<Option name="LARGE_OK" type="boolean" description="Enable
compressing 500+MB files"/>
</CreationOptionList>
So it should work?
Cheers!
Antti S
On 8/7/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> antti siukola wrote:
> > Thanks for your reply!
> > I also have to install the ER mappers ECW JPEG2000 SDK and then
> > compile GDAL against it, am I right? And after that GDAL should work
> > smoothly with ECW's. I'll try that.
> Antti,
> That is correct.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://osgeo.org
