Trouble with OGC Demo
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Aug 8 13:23:19 EDT 2006
Thanks for the info. I can't seem to reproduce this error.
1./ Are you using version 1.0.1 of the workshop?
2./ (just in case) is the CVS revision 1.1.1.1 of
client/default/demo.map?
This is supposed to be a default (non-OGC) mapfile. Is the LAYER/EXTENT
valid to use instead?
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeff McKenna
> Sent: 08 August, 2006 1:00 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Trouble with OGC Demo
> I also have that problem with the "Demo Interface" app in
> that package.
> To get around it, add the following lines to
> /client/default/demo.map in the 'land_shallow_topo_2048' layer:
> METADATA
> "ows_extent" "-180 -90 180 90"
> END
> jeff
> John Schattel wrote:
> > Hi All,
> > I am trying to review the OGC Workshop demo
> > (http://devgeo.cciw.ca/ms_ogc_workshop/index.html) and I seem to be
> > having trouble with the initial installation. When I run the demo
> > the map image is very distorted and the rivers are not in
> the correct
> > location (see http://www.weather.gov/mdl/XML/MapServerError.htm for
> > screen capture). Any suggestions as to what I need to do
> to get the
> > topo to show up correctly and the rivers to appear in their correct
> > locations?
> > Regards,
> > John
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
