Trouble with OGC Demo
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Aug 8 14:41:48 EDT 2006
(John replied directly and that metadata fixed his problem)
Yes this is with 1.0.1, and CVS revision 1.1.1.1 of that mapfile.
I thought it was odd how the projection objects in that demo.map file
had "4236" in it first of all, and it got more confusing after that. No
that mapfile does not work asis, and I had to add that metadata to get
it to work.
So something is wrong with the projection object, or worldfile, or
something.
jeff
Kralidis,Tom [Burlington] wrote:
> Thanks for the info. I can't seem to reproduce this error.
> 1./ Are you using version 1.0.1 of the workshop?
> 2./ (just in case) is the CVS revision 1.1.1.1 of
> client/default/demo.map?
> This is supposed to be a default (non-OGC) mapfile. Is the LAYER/EXTENT
> valid to use instead?
> ..Tom
>> -----Original Message-----
>> From: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeff McKenna
>> Sent: 08 August, 2006 1:00 PM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] Trouble with OGC Demo
>> I also have that problem with the "Demo Interface" app in
>> that package.
>> To get around it, add the following lines to
>> /client/default/demo.map in the 'land_shallow_topo_2048' layer:
>> METADATA
>> "ows_extent" "-180 -90 180 90"
>> END
>> jeff
>> John Schattel wrote:
>>> Hi All,
>>> I am trying to review the OGC Workshop demo
>>> (http://devgeo.cciw.ca/ms_ogc_workshop/index.html) and I seem to be
>>> having trouble with the initial installation. When I run the demo
>>> the map image is very distorted and the rivers are not in
>> the correct
>>> location (see http://www.weather.gov/mdl/XML/MapServerError.htm for
>>> screen capture). Any suggestions as to what I need to do
>> to get the
>>> topo to show up correctly and the rivers to appear in their correct
>>> locations?
>>> Regards,
>>> John
>> Jeff McKenna
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
