Trouble with OGC Demo
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Aug 8 15:10:57 EDT 2006
I've scanned the dist and found a few mapfiles with "4236", which I have
changed to "4326". I have a tagged a 1.0.2 release for this (and a few
small other items). Before I update the package online, I'd like to
know what got more confusing afterwards?
..Tom
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jeff McKenna
> Sent: 08 August, 2006 2:42 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Trouble with OGC Demo
> (John replied directly and that metadata fixed his problem)
> Yes this is with 1.0.1, and CVS revision 1.1.1.1 of that mapfile.
> I thought it was odd how the projection objects in that
> demo.map file had "4236" in it first of all, and it got more
> confusing after that. No that mapfile does not work asis,
> and I had to add that metadata to get it to work.
> So something is wrong with the projection object, or
> worldfile, or something.
> jeff
> Kralidis,Tom [Burlington] wrote:
> > Thanks for the info. I can't seem to reproduce this error.
> > 1./ Are you using version 1.0.1 of the workshop?
> > 2./ (just in case) is the CVS revision 1.1.1.1 of
> > client/default/demo.map?
> > This is supposed to be a default (non-OGC) mapfile. Is the
> > LAYER/EXTENT valid to use instead?
> > ..Tom
> >> Sent: 08 August, 2006 1:00 PM
> >> I also have that problem with the "Demo Interface" app in that
> >> package.
> >> To get around it, add the following lines to
> /client/default/demo.map
> >> in the 'land_shallow_topo_2048' layer:
> >> METADATA
> >> "ows_extent" "-180 -90 180 90"
> >> END
> >> jeff
> >> John Schattel wrote:
> >>> Hi All,
> >>> I am trying to review the OGC Workshop demo
> >>> (http://devgeo.cciw.ca/ms_ogc_workshop/index.html) and I
> seem to be
> >>> having trouble with the initial installation. When I
> run the demo
> >>> the map image is very distorted and the rivers are not in
> >> the correct
> >>> location (see
> http://www.weather.gov/mdl/XML/MapServerError.htm for
> >>> screen capture). Any suggestions as to what I need to do
> >> to get the
> >>> topo to show up correctly and the rivers to appear in
> their correct
> >>> locations?
> >>> Regards,
> >>> John
> >> Jeff McKenna
> >> DM Solutions Group Inc.
> >> http://www.dmsolutions.ca
